Nothing as it is plugged into a computer but still not starting all you could hear at first was a little sound coming out of it but it still won't start up
Assuming that "wont start up" means that the drive letter is not visible thru windows explorer/my computer, which is already installed and booted from an internal hard drive...
the seagate drives, often, require a patch to work with some windows installs- especially if it is larger than 3 terabytes, and occasionally, if larger than 1 terabyte. if this is the case, the patch is most easily obtained by emailing customer service.
if this is not the case, please provide more specifics as to your computer, your version of windows, and exactly what it is not doing when you say 'not starting"
SOURCE: External hard drive
Try these steps: - Right-click on "My Computer" - Click "Manage" - Click on the "Disk Management" icon in the left column (Under the "Storage" category" - If your disk appears on the right-hand side, then try to right-click on it and create a partition. The issue may just be that, since the disk is not partitioned/formatted, a drive letter has not been assigned, which would cause it to not show up in the "My Computer" list Good luck!
SOURCE: external hard drive not registering with the computer
WOW!! I was out of options and was desperate to find a fix for my External. So i took it out of its case and looked it over like the other solution states. I decided to plug it in while it ws out of its case, and i began squeezing it among other things. Finally when i pushed on the area on the bottom where you can see the disk is located, it grinded for a second. After that my drive started to work again!!!!!!! Unreal i thought i ws gonna lose everything i had. Id recommend trying this as a last resort and it dont take alot of pressure, just press on it until you feel the disk vibrate.
Hope this helps someone else as well.
SOURCE: hard drive not recognized
hi I am using Hitachi external hard disk with aluminum case. When I connect my hard disk with my PC it is not recognizing my hard disk. I want retrive my data from the hard disk please let me know the solutions.
Thanks,
K.Venki
SOURCE: Computer freezes on start-up when western digital
This is a known problem with these drives. Disabling USB legacy support in your Bios should solve the problem., it did in my case but at the expense of not being able to boot from a USB device. Definitley a problem with their enclosure or drive.
Ken D
SOURCE: MY COMPUTER WON'T RECOGNIZE MY EXTERNAL HARD
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
if your computer came with a motherboard disk the drivers could be on it
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seated
hope this helps
