I tried with partiotion manager but not success i tried by shrinking but not success after recovery to factory settings
SOURCE: windows
You may have a boot sector virus. At my bench I would remove your hard drive and install it on one of my towers and run a virus scan on your hard drive. Recovery from a boot sector virus is very difficult using tools found in Hiren's Boot disc, a cdrom that contain various programs to recover a hard drive.
Lastly, you may simply have lost the boot strap loader (even though this doesn't make any sense if you have used your recovery CD and recovery partition with success. If you boot and hear a beep, press F8 repeatedly immediately after the beep and you'll receive the recovery bootup option screen, choose Safe Mode first and see if that works, if not choose last know good configuration and otherwise if offerred choose use System Restore.
If all this fails you as a user you need service from a professional.
Hope this has helped or fixed ya.
Worldvet
SOURCE: i formated completelly hdd (acer 7720g) i want to to recreate pqs
You cant access the recovery partition because you probably has deleted them accidentally. Try to delete all the partitions and use the recovery CDs that come with your computer, they could help.
Good luck.
SOURCE: HP Pavillion WebCam Unknown Device (Not Working) plz help !!
sounds like that particular webcam isn't compatible with vista.
SOURCE: HP Laptop Recovery Parition "Not Found" error!
To resize a partition with Windows Vista, follow these steps:
Be sure to back up any valuable information, because there is a
slight chance that data can be lost when dealing with partitions.
1) Click on the Start menu
2) Right click on Computer and click on Manage
3) You may get a User Account Control dialog here; just click Continue
4) In the left pane, open up the Storage category and click on Disk Management
5) Here, you will find your partitions for your disks. Right click on the partition you’d like to modify.
6) Click on Extend Volume or Shrink Volume to extend or shrink the selected partition.
SOURCE: to create a recovery partition in harddisk
Unfortunately the Recovery partition could not be reacreated manually. But you can recover it by using the Y410 Recovery Disc but that means reinstalling everything and youll end up with windows vista again. You can reinstall XP but do not delete the partition that usually has 10-15GB of space because that is the hidden partition for the recovery. You can call 18774536686. If your computer is out of warranty, it would only cost you 59$ for the recovery disc
