Water Sport Logo
W
Wayne Calcutt Posted on Dec 24, 2014
How to remove the inner steering cable 2003 Yamaha xlt 1200 wave runner
5 Related Answers
Anonymous
  • 207 Answers
  • Posted on Jul 08, 2009
SOURCE: Overheating YAMAHA XLT 1200 jet ski
you may have something clogged in a water passage but more than likley u have a bad sensor the sensor is located on the main exhuast if you go on the right side of the ski and look in the engine compartment it will be located at 9 oclock u will see it sticking out of the exhuast with one wire comming out after u run the ski and the buzzer goes off pull the seat and see if the engine is really hot if u can not touch it will be hot but it has to be very hot for the sensor to pick it up if u can touch the motor and exhuast it is a bad sensor
Anonymous
  • 207 Answers
SOURCE: how do we start a yamaha 1998 xl 1200 wave runner
first put a new battery in it. then put your lanyard in the handle bar clip push the start button make sure that you have a life jacket on when your in the water and make sure that u attach the lanyard to your wrist or life jacket
Anonymous
  • 207 Answers
  • Posted on Jul 09, 2009
SOURCE: does a yamaha wave runner have to be in the water
no but do not let it run for more than thirty seconds out of water and dont rev over 3 thousand
protek480
Craig Butler
  • 1730 Answers
  • Posted on Aug 29, 2009
SOURCE: 95 yamaha wave runner starts
Have you changed the 'fuel filter'. That's where you start.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Anonymous
  • 346 Answers
  • Posted on Dec 26, 2009
SOURCE: yamaha 1200 wave runner water in the cylinders
It could be. Do a compression test to ensure that each cylinder is achieving compression, and ensure that the engine does not make awkward noises during cranking.
If the engine was stopped manually, chances are it was not affected at all by the water. Change the oil, however.
1helpful
2002 Xlt 800 runs great on the lift, then bogs and dies under throttle in water
it is possible that it is a carby problem or pump diaphragm
the problem indicates insufficient fuel when under load from the pump ( not under load when out of the water)
2answers
What is wrong with my wave runner
Make sure you are using Yamaha oil not an off brand. It does make a difference.
How do I Change the idle speed on a 1994 Wave Runner
find where throttle cable attatches to carbs and on that wheel there is a lip on the inside and a screw should be there that you adjust the tickover !! P...
My 95 yamaha waverunner 3 will crank but won't stay ctanked what's going on?
check connections clean and no breaks in wires , check solinoid and starter in good order !
How many hours will a xlt 1200 rebuild last for
If a rebuild was done to new specs and there were no short cuts or reused old bits because they looked good and were in side limits I would expect around 75% of the new time up to when the rebuild was necessary i9f not more. A rebuild if done properly should last as long as the original motor but unfortunately the cost causes most people to take shot cuts and use after market parts so the useful life will be less
1helpful
ABOUT HOW MUCH IS TO UNLOCKED A 2 STROKE WAVE RUNNER 1200XL LIMITED
no idea on price but this sort of thing is used in salt water so although a new set of rings and a quick hone of the bore will sort it and maybe a new crank bearing as its obvious someone didnt put oil in with the petrol but the problem i have had with a lot of these fun machines is that getting the engine apart after salt water use is ?well lets just say difficult
1helpful
Adjustment on oil injection on xl 800
There is no adjustment on the oil pump it is a steady direct drive/flow system. If the oil pump is not working correctly you have two options. One is to replace it for around $400. The other is to remove the pump, cover the opening with an aluminum plate, and pre-mix your oil and gas at a 50:1 mixture.
3helpful
Manual for wave runner 1991 WR650P LX
http://www.boats.net/parts/search/Yamaha/Waverunner/1991/WR650P%20WaveRunner%20LX/JET%20UNIT/parts.html. I hope this link helps, this should tell you all you need to know. Thanks for using fixya, mike
Top Yamaha Water Sport Experts
Bob G
ADMIN Eric
ADMIN Eric
johnny bonacci
johnny bonacci
Are you a Yamaha Water Sport Expert? Answer questions, earn points and help others
