This isn't the correct place for your problem, but I am sure, somewhere in settings, you can choose to over-record shows a set amount of time such as 10 mins or half an hour. See your manual for your YouVIew box, even the FAQ's or troubleshooting may help. Please re-post in the relevant category if I haven't been of any help to you.
This will depend on your weight, the amount of
time you exercised, and the intensity. I
weigh 190 pounds and usually jump rope for 1hour at an intensive speed . I
usually burn about 1035 calories a workout. At a slower pace, I would only burn
690 calories. My workout buddy weighs 150 and usually burns about 730 calories
in 1hour.
Hello- The code indicated- F9 - indicates a fault in the door lock circuit. The usual part that fails is a little switch by the latch. The full-power extended cycle burned out the contacts. The part is available, but fairly difficult to replace, so consider service. If this is the only problem you have after 'self-cleaning', consider yourself lucky. This cycle is called 'self-destruct' by most techs. Please acknowledge this post if the info is helpful- have more if needed. Thanks- Ed
Press the speed button (or something like that) to cycle through the possible speeds. If only two they will be normal and extended (sometimes called super). Sometimes there are three: normal, long and extended. Some recorders let you set the speed on the same menu that you use to set the recording time.
Jim,
Although you have deleted the recording the DVD recorder still sees that space as have been being used. The space should be reusable however the area has been used before (therefore not considered unused space).
By deleting the recording you should have no problem going over the area when it is needed.
Happy Recording
Rob
T30 defaults to an opening display screen based on where you were when you last used the device. When leaving from the record folder and record mode, you will always open with the record-ready screen. If you left your T30 while in the music folder playing a music file, you will be returned to that.
This record-ready display screen has a numeric and bar time line. The numeric values of the line are in hrs:min:seconds. This line is also split: the right half of the line indicates the total amount of available recording time, while the left half indicates your time as you record. If you compare the values of the right and left sides of the numeric bar while you are recording, you will see that the right side is diminishing as the left side increases in numeric value. When you complete your recording and save your track, the right side will now indicate the new total time (the amount your screen first displayed LESS the time value of the track just recorded).
When you are playing a music file, if you watch the time display, you will see the numeric information changing in the same way. The left side indicates how may hrs:min:seconds your track has played while the right side indicates the total time value for that file and will be correspondingly decreasing while you play your music file.
So in the short, you don't need to worry much about your display screen unless you open in the wrong folder or you need more recording time than is available. Then it has a message for you.
A 95* White cotton, heavy soil ........ 5.5kg 2hours 30/40 mins Fast spin
B 40* White cotton Heavy soil .......5.5kg 1hour 40/50 mins Fast spin
C 95* White cotton and linen without special finishes......5.5kg 2 hours 20/30 mins Fast spin
D 60* Colour fast cotton, linen or viscose without special finishes......5.5kg 2hours 5/15 mins Fast Spin
E 40* Non-colour fast cotton, linen or viscose.....5.5kg 1hour 40/55 mins Fast spin
F 50* Synthetics, coloured nylon, polyester, acrylic & cotton mixtures, cotton or viscose with special finishes, coloured polyester & cotton mixtures.....3kg 1 hour 5/15 mins Slow Spin
G 40* Acrylics and tri-acetate blends of these fabrics with wool, polyester & wool blends....3kg 40/50 mins Slow Spin
H 40* Wool, shrink resistant machine washable wool, woolen blankets..... 1.5 kg 1 hour 15/25 mins Fast Spin
H...(Wool mixtures with cotton or rayon.....2.5 kg)
J 30* Silk, printed acetate.....3kg 55 mins/1 hour 5mins... Slow Spin
K Quick wash for freshening up lightly soiled items. Warning... not for woolen, silk or delicate items.....1kg 35/45 mins Slow Spin
L Cold wash, cold fill only, no heating action....3kg 55mins/1hour 5 mins Slow Spin
M Rinse and Fast Spin... cotton......5.5kg 55 mins/1hour 5mins...Fast Spin
N Rinse and Slow Spin... Delicates....3kg 30mins Slow Spin
P Fast Spin .... cotton.... 5.5kg 15 mins Fast Spin
Q Slow Spin.... delicates.....3kg 15 mins Slow Spin
