Tablets & eReaders Logo
S
Scott Crowe Posted on Dec 23, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When playing games on my Kindle Fire 7" HD, the apps unexpectedly close and return to home screen
zcomputerwiz
Level 2:
Scholar:
  • Expert 92 Answers
  • Posted on Dec 23, 2014
zcomputerwiz
Expert
Level 2:
Scholar:
Answers
92
Questions
0
Helped
37071
Points
265
When was the last time the tablet was turned off (not just put into sleep mode)?
To turn off the tablet, hold the power button for two or three seconds, then tap "shut down" when asked if you want to shut down your Kindle.
After the device has completely turned off, press the power button to restart.
Please reply with more information if this did not fix your problem!
See the following page for more information:
Quick Fix Slow or Frozen Screen
I need to download the Google play store on kindle fire hd
You can get the Kindle Fire apps by a google search or from searching xda developers . Gapps is google apps.
Screen does not show a status bar any longer. how to I recover it?
Amazon.com Kindle Help Forum
www.amazon.com/gp/help/.../kindleqna?ie...
Amazon.com, Inc.If you have a newer Fire you swipe down from the top of the home screen to open it. ...I can't get the settings bar to show up, because swiping doesn't work. .... Does anyone out there have any ideas on this problem? .... have erased ALL of them) still no status bars/times/access to anything. oh and mine is the kindle fire hd.
About Charging Your Kindle Fire - Amazon.com
www.amazon.com/gp/help/.../display.html?ie=UTF8...
Amazon.com, Inc.Kindle Fire 2nd Generation: Fully charges in 3.3 hours; Kindle Fire HD 7": Fully ... The battery indicator at the top of your screen should also have a lightning ... You can showthe percentage of the battery charge in the Status Bar at the ... Your Kindle Fire will not charge as efficiently when connected to a computer and in use.
Navigating Your Kindle Fire HD 8.9 - Amazon.com
2answers
How do I install Googleplay store app?
If you need to install Google play on your Kindle Fire HD, root your Kindle Fire device at first. However, you can't root it like other Android device with one click rooting tool - iRoot, Framaroot, Kingo Root... The rooting process may be a little complicated while it's effective and safe.
For more detailed instruction, please refer to: http://www.iroot.com/how-to-articles/how-to-root-kindle-fire.html
Afterwards, install the Google play. Open run.bat. Choose option 6 and install it.
3answers
How do I download Google play on my Amazon kindle HD?
For more detailed instruction, please refer to:http://www.iroot.com/how-to-articles/how-to-root-kindle-fire.html
How do I delete games/apps from my kindle fire?
  1. From the Home screen, tap Apps.
  2. Tap the Device tab to view apps that have been downloaded to your device.
  3. Press and hold the app you'd like to remove, and then tap Remove from Device.
Downloaded apps you remove from your Kindle Fire are stored in your Apps library and can be downloaded again from the Cloud tab.
To permanently remove an app from your Amazon.com account, visit Your Apps from a web browser. Select "Delete this app" from the "Actions..." drop down menu to the right of the app. If you permanently delete the app, you'll need purchase it again from the Amazon Appstore to install it on your Kindle Fire
How do I transfer apps and content from old Kindle two new Kindle ?
Presumably you have a Google account, go to Google play store, click icon top left looks like 3 lines,My apps, update all, device will install all your apps.
I let my kindle fire charge all night. Then in the morning I turned on a game and it has been running since about 7 it is stuck. What should I do? And why is this happening
Sounds like a rubbish app/game. Delete it.
If you like the game download it again and see if it behaves properly this time.
(apps/games are cheap/free for a reason.)
Good luck.
2answers
Kindle fire hd lockscreen
Prerequisites:
1. Kindle Fire HD 7", Kindle Fire HD 8.9" or Kindle Fire 2
2. Rooted Kindle: http://forum.xda-developers.com/show....php?t=2069117
3. Google Play: http://forum.xda-developers.com/show....php?t=2069329
Custom Locker Step 1. Using Google Play, search for "No Lock". Download and Install No Lock - You may use this link to verify the software: https://play.google.com/store/apps/d...d.nolock&hl=en
Custom Locker Step 2: DO NOT Open No Lock, it will fail. Next, go to the Kindle, open up ES File Explorer or Root Explorer
Custom Locker Step 3: Be sure to enable Superuser on ES File Explorer. Navigate to /data/app, find org.jaf.androidnolock-1.apk - long press on the APK, select Move or Move To. Next, Move org.jaf.androidnolock-1.apk from /data/app to /system/app.
Custom Locker Step 4: Next find org.jaf.androidnolock-1.apk in /system/app. Long press and Choose Permissions (on Root Explorer) or Properties (on ES File Explorer). Change the Permissions to: Owner: Read Write Group: Read Others: Read - Click OK to apply the Permissions.
Custom Locker Step 5: DO NOT Open No Lock. Pull down the Upper Status Bar, Select More+, Select Sounds & Display and change the Screen Timeout to: Never and then reboot the Kindle.
Custom Locker Step 6: Once the Kindle is back to the desktop, open No Lock which is found in the Kindle Apps, select "Locking disabled".
Custom Locker Step 7: Using Google Play Search for MagicLocker Main which you can find here: https://play.google.com/store/apps/details?id=mobi.lockscreen.magiclocker - Download and Install Magic Locker Main
Custom Locker Step 8: Be sure to enable Superuser on ES File Explorer. Navigate to /data/app, find mobi.lockscreen.magiclocker-1.apk - long press on the APK, select Move or Move To. Next, Move mobi.lockscreen.magiclocker-1.apk from /data/app to /system/app.
Custom Locker Step 9: Next find mobi.lockscreen.magiclocker-1.apk in /system/app. Long press and Choose Permissions (on Root Explorer) or Properties (on ES File Explorer). Change the Permissions to: Owner: Read Write Group: Read Others: Read - Click OK to apply the Permissions.
Custom Locker Step 10: Using Google Play Search for MagicLocker Theme - Download and Install a few Themes that interest you. I use Starry lock screen and Jelly Bean lock screen.
Custom Locker Step 11: Launch MagicLocker Main, click on Next, Next, Next - You will now see a popup, click Next and choose Clear Defaults until it Grays Out, click on the picture of a house (Home Button), you will be asked which Launcher to Use, you choose MagicLocker Main <Select Default>.
Custom Locker Step 12: Launch MagicLocker Main, sometimes you are taken to your regular Launcher App, if this happens repeat Step 11. Select "Lost Robot Music" and click Apply. Next MagicLocker applies the Theme and asks if you would like to Customize it, answer Yes or No depending on your interests. I selected No so we can move on. You can always customize it latter.
Custom Locker Step 13: Next MagicLocker will show you an example of the Theme. Unlock it by pulling down the circle in the Android Picture.
Custom Locker Step 14: Now we need to customize the way MagicLocker reacts when you unlock to the Left which is a Phone Call and when you unlock to the Right which is a SMS Application. Unlock straight down just unlocks the screen.
Custom Locker Step 15: OK, lock the Kindle by depressing the Power Button for 1 brief Second until the screen turns black. Depress the Power Button briefly again, you will see the lock Screen. Unlock to the Right, next you are asked which is your SMS Software, I use Go SMS Pro. Check the Box to "Always use this application". Unlock to the Left, next you are asked which is your Phone Software, I use Google Voice and Groove. Check the Box to "Always use this application".
Custom Locker Step 16: Next, let's install the Themes. Find the name of the Themes you downloaded in Step 8. In this example we picked Starry lock screen and Jelly Bean lock screen. So go into the Apps. Find Starry lock screen, click on Starry lock screen and select "Install this theme". The installer will process and you will be back at the MagicLocker main Theme Menu. Exit MagicLocker, then go to Apps, find Jelly Bean lock screen, click on Starry lock screen and select "Install this theme". The installer will process and you will be back at the MagicLocker main Theme Menu.
Custom Locker Step 17: Now we need to let MagicLocker know what is your Default Launcher, so launch MagicLocker, find Preferred Home Launcher, click on Preferred Home Launcher and select your Launcher, we use Nova Launcher Prime.
Custom Locker Step 18: Let's eliminate the Ads from ever appearing again. Open either ES File Explorer or Root Explorer, navigate to /system/app find the dtcp_apk.ap, long press dtcp_apk.apk select Rename. Rename dtcp_apk.apk to dtcp_apk.old.
Custom Locker Step 19: Reboot the Kindle.
Custom Locker Step 20: Whenever you reboot, the Kindle Fire Framework starts before anything else, so you may see the Kindle lock screen at Reboot IF you do not let everything start. If you can not wait 5 to 10 minutes, unlock it and let all the services start, usually 10 minutes is sufficient. Once you unlock it, you will notice there are no more Ads! After 10 minutes No Lock Service kicks in and disables the Kindle Fire Lock Screen. We have attempted to play with the start-up timing and ended up with Framework missing, so Amazon was smart when they thought out this function. Also, the service that controls the lock screen is part of the same group that displays the Kindle Framework when you unlock it. Finally, if you do wait 10 minutes you will never see the old Kindle Fire Lock Screen!
That is it! Next we will offer you a solution with the stock lock screen but you will need high resolution photos to make it function properly. Be sure to look at our new Backup and Recovery Software for the Kindle Fire Series: http://forum.xda-developers.com/show....php?t=2096888
Top Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
