A photograph of the circuit close to the connector or the code written on the condenser to make L business little.
You might try going to this webpage
https://www.alesis.com/sr16
and from the docs&downloads section download and search the Reference manual. It's also here http://www.burnkit2600.com/manuals/ALESIS_SR-16_OM.pdf (this looks more like a user guide though)
Failing that, choose 'support' from the th top of the page and either contact Alesis support or else ask your question in the 'community' (which you will have to join). Another community which deems to have an interest in the SR-16 is www.circuitbenders.co.uk but I think it unlikely that they could direct you to a circuit diagram, though it is slight possibility that someone might know the value of the capacitor C5
23.December.2014
Il est rond et jaune. je place un exemple du condensateur
Is that a picture of the actual capacitor, or just a yellow ceramic disc capacitor ?
the condenser is of this form. it is an example only
mine nonreadable… is roasted.
Add a Commentthere must be a code of 2 or 3 figure written on the round and yellow ceramic condenser. It is almost to support on 2 large condenser in the shape of bottle That takes to me is coded to repair it.
didn't Pet Vanderwaal answer this question on 11.December.2014 ?
Pete Vanderwaal answered this on 11.December.2014 for you - 2200mfd / 16volt ???
it is not the good condenser which gave. I speak about the ceramic condenser round and yellow and not in the shape of bottle… I am sorry I use an English French translator.
I need the 3 digits on the condenser.
I put a photograph of site of the roasted condenser.
Serge, I see that in your picture the two blue electrolytic cylindrical capcitors (condenors appear damaged as well, one cerainly is. In this picture have you removed the yellow ceramic capcitor already ? or it so roasted that I cannot see it ? In either case I cannt determine its value. As you thought you may need to refer to proper circuit diagram to determine its value. I suspect that the information you need can be obtained in one two ways (i) contact Alesis and hve them tell you (ii) an owner of a working SR-16 (who you might be able to comtact by browsing the various forums) could look at their circuit board at read the number of the capacitor from there. That is all I am able to suggest, unless you can determine the nature of that part of the circuit and thereby work out what value capacitor would be good (from its position, it looks like it might be power supply filtering capacitor). And you sould remember what another Fixya 'expert' says, that (often) capacitors do't just roast there is sometimes a reason for this, and replacing the capacitors may not slve the problem. But sometimes cmponents do spontaneously fail. I hope this comment translates well, I apologise that my French is not good enough to write in that language. Unfortunately, I am unable to give you any more advice. Joyeux Noel ! 24.December.2014
I thank to you you are very nice, the round condenser is not there (to crumble). At Alesis do not answer me. I go continued to seek. The cause of the problem. it was not the good block of courrant VCC instead of VAC. If you know a person who would like to take a picture that would help much. Still thank you!!! :))
Merry Christmas !!! :)
