Went to the dealer; they do not handle parts for this TV. TV is a Proscan 19" LED TV PLED1960A-E. Need a replacement base for this TV.
They make universal bases, but first I would suggest contacting Proscan: http://www.proscanvideo.com/contact-us.asp.
SOURCE: Power Cord
http://oncorpus.com/down/down.htm
It's probably easier to go to ebay to get one.
http://cgi.ebay.com/AC-Power-Adapter-LCD-F-12-Volt-5-Amp-12V-5A-DC-Supply_W0QQitemZ280306032459QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item280306032459&_trksid=p3286.c0.m14&_trkparms=72%3A1205%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318%7C301%3A1%7C293%3A1%7C294%3A50
SOURCE: need to remove base from Proscan 32" TV
The stand
can be removed by unscrewing six phillips-head screws from the back panel. A
plastic insert plate is provided to cover the bottom hole that is left when
removing the stand.
thats what i found from this site
http://www.crutchfield.com/p_68332LA30Q/Proscan-32LA30Q.html?tp=161
theres a manual on the left side of the screen just under recommended accessories
doesnt show how to remove it but might be helpfull for your settings
hope it helps
SOURCE: does the Proscan 47" LED
yes it does , if you are viewing the TV from the rear it is located in the back on the lower right , on the right side of the RCA's . here is a link to give you a visual , just wait for the manual to pop up .
http://www.managemylife.com/mmh/owner_manuals/15565/PROSCAN-LCD-Television-L1001098
SOURCE: I have a Proscan 32
You will have to order it from Proscan. The part# and web address should be in your owners manual.
SOURCE: I need to buy a new or used base for my 42 in proscan lcd tv.
Other than going to Thompson who is RCA/GE/Proscan you can Google the model number with base to see what is available.
