We have changed light bulb
It probably is a bad switch, in most firdge the switch is installe in a pop-lock construction. maybe the spring inside the switch is busted. Also please check the bulb you bought. it should be rated for refrigerators or else it wont work.
SOURCE: The light on the fridge side is out and there is a buzzing sound
Try shutting down your unit, unplug it from the wall and wait a few minutes - plus it back in and turn on see if it solves the problem otherwise you may have a faulty board.
SOURCE: The digital number lights are
Not a bulb. Some of these units have a power board beside the compressor. Need a complete model number located in the refrigerator section.
SOURCE: HOW TO CHANGE A LIGHT BULB INSIDE THE FRIDGE?
You usually unclip the bulb cover by squeezing it gently. Then unscrew the bulb. Take it to the store to get one that matches. Replace, then refit cover.
