Can not get speed control to get out of low speed (1 bar on indicater. Was OK , recently moved.
Hi, the speed control could be faulty, see if you can spray some Wd40 or contact cleaner in the gap and see if that improves things...is it the one with the snail , rabbit speed sign ?
one bar on the indicator does imply low battery power ...is it flashing ? if it is then that's a fault condition
Regards
Rob
www.gewizrepairs.co.uk
SOURCE: My Pride Hurricane PMV will not go forward or
Make sure that the manual brake release/freewheel lever is in the DRIVE position. The click indicates the brakes are being released but the motors are not kicking in. I hope this helps- good luck!
