How to remove air filter for cleaning
If you are talking about the metal wheel inside, the only way I have been able to clean it completely is to turn it over, unscrew all the screws, carefully lift it apart, and then you can lift the wheel out. But after you clean it, make sure its completely dry . I usually leave it out in the sun so it drys completely. Then while its out, you can either take a can of the air, like you use to clean computers, or if you have a vac that you can blow air from, or just simply use a soft cloth, brush, whatever you have that can clean it. `its a pain to do, because they def don't mention about how dirty it gets inside there, but honestly I love my purifiers so much, even though its a pain to do, I do it anyway! hope this helps you out alittle!!!
