Well, Your Modem will have the cable wire from the wall going to it... from the modem the wire will go to the "Input" or "IN" line on the router. Then, there should be other ports (about 3 - 5 on most) where you can plug in a cable and connect THAT cable to the computer. Usually, the "IN" wire on the router will be closest to the power wire and/or away from the other ports. Try that and see if it works.
