In booting option setting only the name of the hardisk snd the windows boot mananger
SOURCE: STARTUP ISSUE ON TOSHIBA 4015CDT
Your BIOS is probably not set to boot from a CD-ROM. Luckily I have the same laptop so if you press and hold the "c" key when it boots up and keep holding it until it beeps at you it will then boot from a cd. You could also press esc and go into the BIOS if you're adventurous.
SOURCE: My Notebook acer travelmate 2450 doesn't start
Check with someone you know to see if they have a USB external CD or DVD drive that you can borrow. Then set it to boot from USB. There is also a possiblity that you have a corrupt CMOS fireware. See if you can download an BIOS firmware update and place it on a external floppy and install. Good Luck
SOURCE: Samsung mini laptop n148. Windows
It sounds to me that unfortunately you have an error on your recorded CD and there will be nothing you can do to repair that.
The installation of Norton should not cause the problem itself an error on the hard drive will usually cause that problem.
SOURCE: Came back to house and
Download and burn your Windows 7 Recovery Disc..The Windows 7 Recovery Disc can be used to access a system recovery menu, giving you options of using System Restore, Complete PC Backup, automated system repair, and a command-line prompt for manual advanced recovery.
Instructions >>>
Windows 7 32 bit Repair Disk
Windows 7 64-bit Repair Disc
1.Download the appropriate .torrent file from above that corresponds to the version of Windows 7 you have installed.
2.Download and run µTorrent.
3.Open the .torrent file you downloaded with µTorrent. (File -> Add Torrent)
4.Select where you want µTorrent to save the 7 Recovery Disc.
5.Wait for it to download.
6.Burn the .iso file that µTorrent downloaded to a CD using these instructions.
When you want to use the recovery center, put the CD in your drive and boot from it. This is usually done by pressing F8 at startup, or changing the boot drive order in the BIOS.Repair Windows 7 using Startup Repair Tool.
