2001 Mercedes-Benz ML 320 Logo
d
dwayne zangarine Posted on Dec 22, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why does my 2001 mercedes ml 320 rear end sway on wet surfaces
Nothing yet
ivan whisker
Level 3:
Genius:
  • Mercedes-Benz Master 1,164 Answers
  • Posted on Jan 06, 2015
ivan whisker
Level 3:
Genius:
Answers
1164
Questions
9
Helped
302886
Points
2628
Is there plenty of tred on tyres are they inflated to correct level rear shocks worn loose suspension components
Daniel Mc Entee
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Mercedes-Benz Master 1,449 Answers
Daniel Mc Entee
Level 3:
Renaissance:
Answers
1449
Questions
0
Helped
276036
Points
3556
Sounds like trouble with your ABS ,check the codes for failed ABS it can be the relay ,or sensors or the ring behind your rear brakes.
5 Related Answers
Anonymous
  • 405 Answers
  • Posted on Dec 27, 2008
SOURCE: mercedes ML 320 1998. My horn does not work
About four things to do, first check voltage at horn with key on and button pressed. If voltage there try moving the small gap screw back and fourth a few times. If that doen't work replace horn. If no voltage check fuse and horn relay, you should be able to hear the relay click when you push the horn button, If not and fuse is ok. Switch relay out with another on on the car. If that doesn't fix it check the horn button for continuity.
Anonymous
  • 3 Answers
  • Posted on May 03, 2009
SOURCE: 320 Ml Mercedes-Benz
Go to advance auto or auto zone and have the do a trouble code read ( it is free).
The plug is located under the drivers side dash to the left of the brake pedal.
Press the esp off button on the dash and see if ithas an effect. on acceleration
Next I would try this it is expensive.
If it feels like it is bogged down when you first start to acceleratewill only creep about 10 to 20mph it may be the mass flow sensor located between the air filter and the throttle body. It has an electrical connection. Sand eats them up and it is a common item about $200.
Anonymous
  • 203 Answers
  • Posted on May 29, 2009
SOURCE: I have a 1998 Mercedes
First you need to see if the remote central locking is working. It sounds like your transponder(key) is un synchronized. Even if the central locking is working there is a d.a.s.(driver authorization problem). Try your other key if you have one. There is a way to resynch the key w/o a factory scan tool but you have to follow the directions exactly and be quick. Point key at door receptor.( grab handle area) Hold the lock button down and press the unlock button 5 times in 10 seconds while holding down the lock button. hold the lock button down the entire 10 seconds even if you've hit the button 5 times. after the 10 seconds is up release and hit the lock button again. The d.a.s. system shuts off your fuel pump when their is an authorization error. It is a common problem in 98 and 99 ml's. Your owner's manual tells you how to resynch the key if my description is difficult to follow. Hopefully I have been helpful
Anonymous
  • 580 Answers
  • Posted on Jul 12, 2009
SOURCE: 2001 ml 320 SRS light came on after battery
Take your car to an independent Mercedes Benz Mechanic Let your dealer know you will no longer be using him for you cars service.
The SRS is for your airbag system and is unable to deploy on a low battery have your NEW mechanic reset this when your battery is charged
Anonymous
  • Posted on Apr 25, 2010
SOURCE: my 1998 mercedes ml320 starts for 1or 2 seconds and then stalls.
You either have to replace the battery in your key fob or have it reprogrammed. Verify this by trying the second key, if you have it. AAA told me that you can reprogram it by leaving it in the ignition, with the key turned to the first position, overnight. I haven't tried it.
2009 Mercedes Benz ML350. Where is the fuel pump relay and fuel pump fuse location diagram please?
Question edited for clarity.
Question moved to model category.
105 for the fuse and 'O' for the Relay.
All the fuses and all the relays.
Fuse Box Diagram Mercedes-Benz M-Class (W164; 2006 ...
https://fuse-box.info > mercedes-benz > mercedes-benz-...
Here you will find fuse box diagrams of Mercedes-Benz ML280, ML300, ML320, ML350, ML420, ML450, ML500, ML550, ML63 2006, 2007, 2008, 2009, 2010 and 2011, get ...
Fuses W164 M-Class 2006-2011 Diagram, Box Location ...
https://www.mercedesmedic.com > fuse-box-location-d...
Fuse locations on Mercedes-Benz M-Class W164 2006-2011. Main fuse box and relay box is located in the engine compartment. Rear, passenger side in the trunk.
Model: ML 320 CDI ML 320 BLUETEC ML 350 ...
Years: 2006 2007 2008 2009 2010 2011
Chassis: 164
2007 Mercedes-Benz M-Class ML320 CDI 4dr SUV AWD. Where are the window fuses located in a 2007 ml320 cdi
Question edited for a lot more clarity.
These things have fuses boxes all over the place and are a nightmare to work on :>D
Here you will find fuse box diagrams of Mercedes-Benz ML280, ML300, ML320, ML350, ML420, ML450, ML500, ML550, ML63 2006, 2007, 2008, 2009, 2010 and 2011, ...
Chassis: 164
Make: Mercedes-Benz
https://mbworld.org > attachments > m-class-w164
PDF
9 pages
1helpful
Where is the stamped chassis number for ML320 cdi 2001 model?
Try this site, Good Luck.http://www.mercedesmlclub.com/vin_plate.html
Ml 320 automatic is moving but soon after apling gear is cut power off
Have a diagnostic check done. Check codes, wires, and valve body. Just a start.
1helpful
2002 ml 320 power steering leak
leaks out where the resivore or lines or the steering box which ever it maybe you will have to replace.
1helpful
My 1999 ml 320 steering wheel spins all they way around 360 degrees and it makes a straining noises when it turns. and it's very loose. help
Check your power steering fluid. Screeching will come from the fluid being too low and would affect the steering. It will also burn out the pump if you don't keep it full.
Repleace ac compresor for ml 320 99 year
evacuate the system,remove a/c lines from compressor,remove belt,then 3 bolts,2on the body of compressor and one on the back. thats simple.
44helpful
2answers
My 2002 ml 320 press cd button it says no cd player installed
my 2001 ml 320 when i press cd button it says no cd player installed massage. There is 6 cd changer in the back of the car ., Any suggestion for fix the cd player?
Please help.
Top Mercedes-Benz Experts
ZJ Limited
ZJ Limited
xxxxxx xxx
Arnie Burke
Arnie Burke
Are you a Mercedes-Benz Expert? Answer questions, earn points and help others
