The defrost water from the melted frost (ice) collects in the bottom of the freezer. If there is no plugged up drain, then you must remove the water manually with a sponge and bucket after a defrost cycle.
If there is frost forming at the bottom to the door, your door gasket is leaking at that location. You may be able to relax gasket back in place with hair dryer, be carefull you can melt gasket. If it is sheets of ice, your defrost drain may be frozen
Good day, The aerosols help. But, hurry up with any type of refrigeration equipment is many times a quick way to disaster. Go slow and thorough. A little lost food is far better than a messed up machine. Patience is your friend here.
check the timer maybe your Fridge it has timer to defrost or is set to auto defrost try to make set to manually defrost..or if you have manual of that item read it for guidance..
My whirlpool Fridge/freezer powers up but both fridge and freezer notworking,have defrosted the freezer but noluck,have turned on foran hourand then back again,as per user guide still no luck.
Either your defrost timer, defrost heater or defrost thermostat has failed.
All parts are located behind the lower back panel inside the freezer.
Most likely are the defrost heater and defrost thermostat.
JennyT just trying to help with this. I assume this is a self defrost model. If so then is there an ice build up on the back wall? If so then the unit isn't defrosting. That is why pushing the Fast Freeze button is no longer working. You can get by however. Remove all the food from the freezer, put a vacumn in the freezer and shut the door. Turn on the vacumn, this will pull the warm air thru the freezer and in 30 minutes to an hour it will be defrosted enough to work until you can get someone to replace the 1 of 3 parts that the defrost system uses. The vacumn is what I use to defrost my nonself defrosting freezer. Sorry I couldn't be of more help.
