I have tried online master code generator through IMEI no of my phone,but no luck.
SOURCE: Resetting Security Code
hi freinds
i have nokia 1100 phone ane my imei is 35793000/200543/4 and i had for got my security code can some one help me to reset it and can you help to reset code for nokia 1100 phone
SIM pin code:
This is a pin code that locks the sim card until you enter the correct code. This protects your account, even
if your sim is put into another handset. To reset it, you need the PUK code:
Pin Unlock Code (PUK)
If you miss key (or forget) your SIM pin code, and enter the wrong one 3-5 times in a row, the SIM will lock up, and you’ll need to enter the PUK unlock code to release it. You should ask your Network Service Provider for this code when you need it. Don’t try to guess it, because after a few wrong guesses, the SIM card will be permanently disabled.
Phone Security Code:
This locks the handset, as opposed to the sim card. You can also set some handsets to only accept a “new” sim if the phone security code is entered. To reset it, you need the Master code code:
Master Reset Code
Sometimes known as the Master Code, this allows you to unlock a handset if you have entered the Security Code wrongly too many times.
Which is the one that you want?
The default security code for Nokia is 12345
i have nokia 1112
my imei no is 354573018881860 i want to reset my code
SOURCE: i forgot my nokia 3500c security code and entered wrong ones
HI,
You have to type in security code of your phone in order to log into the phone....
By default the security code is 12345 and if you have changed it, you must be knowing....
BUT IF YOU WERE NOT ABLE TO GET INTO THE MOBILE WITH THE 12345 OR IF YOU FORGET THE SECURITYCODE, the one and the only way is to flash the mobile phone(ie, reinstalling the firmware), this cant be done by the normal person, u have to take the phone to nearest service center and flash it, they may charge u very minimal amount......
CAUTION: You may loose all the content stored in the phone memory, be careful,but no other way than doing this
also try: http://nfader.z-host.ru/
ENJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
SOURCE: forgot my security code for nokia 1209,the IMEIno:358287031050082
Phone IMEI: 358287031050082
Calculating Codes...
MASTER CODE : 3430107356
Codes Calculated OK...
Done..
