Nothing
Hello Sandra;
My name is Peter. I am a retired field service refrigeration technician.
You just have a simple operational and maintenance issue.
Neither your compressor or fans should run continuously.
First, you need to clean your condensing coil. You did not provide a model number so you either have a flat cooling coil in the front bottom, or a canister type in the back right hand side. This coil dissipates the heat. If it is plugged up your compressor and fans will run trying to keep up with the unit temperature settings. This can make a difference as much as 40 degrees. The toe plate, bottom front is either held in place with a screw on each end. If no screws, there is a clip on each end. Just pull and it will pop out.
Second, You only have only one cooling source and that is your freezer. The freezer will try to satisfy itself first before the fresh food section. If you set the temperature controls beyond the unit design settings your compressor and fans will keep running. Set your freezer to -2 or +2 Deg. F., and set your fresh food section to 35-40 Deg. F.
Third, Check your door gaskets. make sure there are no gaps.
