How do I unlock my tablet if I forgot the password?Manual Factory ResetTurn off your Android device. ...Press and hold the "power", "volume down", and "camera" buttons simultaneously. ...Release the buttons once your Android device is powered on. ...Scroll using your "Volume up and down" button until you find the "wipe data/factory reset" option.More items...Recover Android Device in case of Forgot password/pattern unlock an ...visihow.com/Recover...in...Forgot_password/pattern_unlock_an_Android_deviceSearch for: How do I unlock my tablet if I forgot the password?
I Forgot My Password To Unlock To My Tablet?
Factory Data Reset - Factory Data Reset can be accessed through your Settings which can be found either on your main screen or in your Apps/Widgets (tap on 6 squares in upper right hand corner) menu. From Settings, on the left hand column, tap on Backup and Reset. On the right hand side tap on Factory Data Reset. This will take you to a screen that will give you the option to check the Erase SD Card option which, when checked, will ensure that your pictures and any other personal information on this device will delete during the reset. Last, tap on Reset Tablet and Erase Everything.
Tap on Settings.
Tap on Backup and Reset on the left hand column.
Tap on Factory Data Reset on right hand side.
Tap on Erase SD Card. (optional)
Tap on Reset Tablet and Erase Everything.
Or
Hard Reset G2 - In the case of password lockouts or freezing, doing a hard reset on your android device could help you get back to the factory defaults. First you need to make sure your tablet is powered off. Hold down on the Volume + button and hold down the Power button at the same time. As soon as the tablet's screen turns on let go of the Power button but keep the Volume + button held down until you see a large Android in the center of the screen. At this point you will see a screen with boot options. Use the Volume - button to go down to Wipe Data Factory Reset and tap the Power button to select this option. On the next screen use the Volume - button again to go down to Yes and use the Power button to select. At this point it will be going through the wiping and resetting process. When it's done you will see the first screen you came to when you first started the setup. Just tap the Power button to select Reboot System Now.
Make sure tablet is powered off.
Hold down Volume + button and Power button at same time.
When screen comes on let go of Power button.
When the large Android shows on screen let go of Volume + button.
Use Volume - button to scroll to Wipe Data/ Factory Reset
Many people say to push and hold down the Volume(+) and Power button at the same time. Push and hold for as long as twenty seconds until you see a green android with green text.
But, on some devices and some Android O/S versions it takes pushing and holding the Volume(-) and Power button and holding them both down for twenty seconds or so or until you see the green Android and text screen. This will show the Wipe Data/Factory reset option. Select this option by scrolling using the Volume(+) button and engage using the power button. Some devices give you a second screen with a list of *no no no no no* and one line of Factory Reset. Again, scroll to the Reset option using the Volume(+) option and select it using the power button.
If the above doesn't work, either your battery is dead or your device is dead.
Hi, you need to perform a factory reset, follow these instructions:
Turn tablet off. You may need to use two hands in this process to press and hold buttons properly.
Turn on the tablet with power button, wait a full 2 seconds from the time the tablet starts showing the red Motorola logo, then press and hold the down Volume key. (you should not hold down the power button after it turns on and logo appears)
"Android Recovery" will appear on top of screen if timing is done correctly. Release volume button. (if you continue to press volume down at that message, the message will cycle through "RSD, Fastboot, and back to Android Recovery. Make sure message states Android Recovery before you go to next step). If stuck at a RSD protocol or Fast boot screen, reboot the tablet by holding power button then pressing the volume up).
While screen states "Android Recovery", Press volume up button, the screen will say "Entering Android recovery mode" and a few seconds later an Android robot graphic will appear alone on the screen. Release buttons.
Hold down power button and then press the volume up key together to see the Android Recovery screen menu selections.
Use the volume buttons to move up and down through selection in this menu.
Using the volume down button, scroll down to "Wipe data/factory reset"
Tap Power hard key to select option.
Scroll down to select "Yes, delete all user data".
Tap the power button to select. Wiping and formatting data will take a few minutes.
You will return back to the Android recovery screen menu.
Tap the Power button to "Reboot system now" which will power-cycle tablet and eventually power back on to the Initial Set-up / Welcome screen present when you first turned on your tablet.
Hi there! Ignore the other answer, they're giving a generic Google search result. On the screen with the Android, press the power and both volume buttons all together in quick intervals until a new screen pops up. Use the volume keys to select Data Wipes/Factory Reset, then do the same for yes, then restart the tablet
You may have to reset it. let if charge for about 24hrs, 10hrs may work fine too and With the device turned off, press and hold the volume down button, and then briefly press the power button. - Wait for the screen with the three Android images to appear, and then release the volume down button. - Press volume down to select clear storage, and then press power. - Press volume up to start the factory reset.
1. Power the Tablet off.
2. Press and hold the Volume Down button of the device, then press and hold the Power button.
3. Continue to hold both buttons until a bootloader screen appears.
4. Wait for the prompt that says to "Press <VOL_UP>" then press the Volume Up button to start the process. 5. Navigate to Erase content.
All info on tablet will be deleted but not the info in the SD card
The tablet will complete the hard reset process and reboot into a factory default state.
While holding down the volume down (-) button, press the power button to turn on the unit. Once you see Coby logo on the screen, you can release the power button, but you still need to keep holding the volume down (-) button until you see Android robot logo on the screen.
The "Android system recovery" menu will appear on the screen. The volume up (+) button is used to scroll up in the menu list, while the volume down (-) button is used to scroll down. The power button is used to select and/or enter an option.
