The ecm receives a signal from the crankshaft position sensor and sends timing signals to the ignition control module, whick fires the coil. The problem can be the crank sensor or the control module. The crank sensor is inside the distributor. I have pasted a test procedure below to help you troubleshoot.
1994-95 ACCORD EXCEPT V-6
See Figures 8 and 9
Remove the distributor cap, rotor and the inner cover.Disconnect the wires from the igniter.Check for voltage between the black/yellow wire and ground. Battery voltage should be present with the ignition ON . If voltage is not present, check the black/yellow wire between the ignition switch and the igniter.
Fig. Fig. 8: Terminal identification on engines without VTEC
Check for voltage between the green wire ("BLU 2" on VTEC) and ground. Battery voltage should be present with the ignition ON . If voltage is not present, check the ignition coil and the green ("BLU 2" on VTEC) wire between the ignition coil and the igniter.
Fig. Fig. 9: Terminal identification on VTEC engines
Turn the ignition switch OFF .Check the yellow/green wire between the engine control module and the igniter for continuity. Then check the BLU 1 wire between the tachometer and the igniter for continuity.If the wiring is OK and a problem still exists, the igniter is probably at fault.
Vtec engine
Non -vtec engine
