Timberland Tbl-13319jstb-02 Hydroclimb Mens Watch Logo
c
connie cunado Posted on Dec 20, 2014
Second hand does not move?
I tried to press the two botton at bothe side but still its not working..badly needed ur help.:(
  • connie cunado
    connie cunado Dec 20, 2014
    i cant open the add photo entry.:(
How to change skmei 1180 date,week.
In watch mode, push the "mode botton" for approximately 3 second, then the light will flashing and you can move the option by pushing the "mode botton" and change the date and month by pressing "up or down botton"
Apr 09, 2017 • Watches
10helpful
2answers
Showing 6ae on my Tissot T touch. Also cannot synch properly
Press the center button marked "T". The watch should beep once;- Touch the center of the touch-sensitive face until 24H Cm appears in the digital LCD display;
- Press and hold the center button marked "T" for approx. 5 seconds. The watch will beep once and then again a second time, after 5 seconds have passed. The digital LCD display should now read SYNCHRO;
- Press the upper button marked "+" to move the minute hand until it is positioned exactly at 12:00;
- Press the lower button marked "-" to move the hour hand until it is also positioned exactly at 12:00;
- When both hands are aligned together and pointing directly at 12:00, press the center button marked "T" to save your settings.
- Your watch is now synchronized, so no expensive repair work is required!
5034 G-1000 Cannot set Date/Time
gibb erish....the same problem that already happened it on me..but there is a solution for that.just focus..let your excitement blow up if u done it will..
a manual has shown a combination of bottons to press..there is a diagram showing the combination to press so that it will beep. just try.. sometimes i press D go back to A and try long press tell it beeps and so on just follow the manual.. while the hands are still on movement just wait to stop before you press some bottons..be patient our watch is awesome..
3helpful
2answers
Changing the hand time only w/o changing the digital time
For Casio Waveceptor:
--- A
( ) Button Reference
--- B
Set in correct order:
1) Hand Home Position
2) Digital Time Set
1) Hand Home Position:
Press and hold A and B for 5 seconds, Press A to move Second Hand to 12: position: (if not there). Press B to enter Hour/Min set mode. Press A to move both hands to 12: position. Hold A to move hands fast, Press A again to stop hands. All 3 hands are now at 12' oclock.
Press B to exit Hand Home Position mode and enter Timekeeping Mode.
2) Digital Time Set: (hands will self set when done)
Press and hold B for 5 seconds to enter setting mode.
Press A to advance current item or scroll through choices. Press B to set item and advance to next item.
<Order of Items to Set>
GMT Differential -> Daylight Savings auto/on/off -> Seconds -> Hour -> Minutes -> Year -> Month -> Day -> Day of week language -> Auto receive -> (back to Timekeeping Mode).
<Setting each Item>
GMT Differential: Press A untill your time zone is reached (E=eastern, C=central, M=mountain, P=pacific). Press B to set (advances to next item).
Daylight Savings: Press A untill desired DST mode is reached: ("At" auto, "On" after spring change, "Of" after fall change) Press B to set (advances to next item).
Repeat to set: Seconds (resets to :00), Hour, Minutes, Year, Month, Day, Day of Week Language, and Auto Receive (on/off).
For each item, Press A to advance, and B to set.
Pressing B to set last item exits Setting Mode and enters Timekeeping Mode. Hands advance to current time.
Good luck,
Techjoel
23helpful
How to set up time on TAG HEUER SLR CHRONOGRAPH ? what are the functions of the 2 boutons and 2 crowns ?
The crown at 3 o'clock is used to set the time and change modes. The crown at 9 o'clock is used to rotate the flange at the edge of the dial.
The A button at approximately 2 o'clock starts and stops the chronograph function. The B button at approximately 4 o'clock resets the chronograph.
Lap Timer: When the watch is displaying normal time, press the right side crown to switch to chrono mode (the hour hand will indicate CHRONO). This watch measures lap times, press A to start timing the first lap. Press A again to stop the first lap and automatically start timing the second lap (the hour hand will move to indicate you're on the second lap), and so on. You can measure up to 20 laps this way. When you're fininshed timing laps, press the right side crown to see the best lap time. To reset the lap timer, hold down B for 2 seconds. To switch out of chrono and see the normal time, just press the right side crown in.
Chronongraph: To time an interval that is not a lap, just follow the above instructions, but instead of pressing A to stop the first lap, press B and the watch will show the elapsed time to the nearest 1/100th of a second. Hold B to reset.
Crown at 9 o'clock: This crown rotates the inner flange at the edge of the dial and is used to measure total race time (i.e. the total of all the laps). Simply rotate the crown until the the little start trinagle on the flange is aligned with the minute hand. This way, the total elapsed time can be read at any time, similarly to how a rotating bezel works.
To set the time: Ensure the watch is not in CHRONO mode, if so, press the right side crown in. At this time pull the right side crown out until you feel a click.The position the second hand moves to indicates what is currently being set. If the second hand is at 9 o'clock, you are setting am hours, press A repeatedly to set am hours. Then press B and the second hand will move to 6 o'clock, pressing A repeatedly will set the minutes. So on for year (11 o'clock), month (12 o'clock), and day (1 o'clock).
48helpful
6answers
Seiko chronograph alarm
Solution #3 (Posted by Guest on 5 Mar 08) is spot on. Quick and easy method to reset the chrono hands (it was not in my Seiko manual).
Interestingly, this can also be used to set the chrono ahead (or behind--with a little math) for offset timing measurements.
58helpful
7answers
Instructions for casio wave ceptor 4303
Use this page to download a copy of CASIO watch manuals in PDF format. To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
http://world.casio.com/wat/download/en/manual/
You will need a pdf reader on your pc, you will find all instructions in there.
If you don't have a pdf reader you can get one from
http://www.foxitsoftware.com/pdf/rd_intro.php
39helpful
3answers
Reset Stopwatch Hands on CL1111 ?
Try setting the crown to position 2 - i.e. the position normally used to adjust the date.  Then use the top and bottom stopwatch buttons to adjust the minute hand and 1/10th hand respectively.
Top Timberland Watches Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
john h
Are you a Timberland Watch Expert? Answer questions, earn points and help others
