Question edited for clarity and the correct name of maker.
Question moved from Computers to Tablet.
Turn off the device. Press and hold the Volume Up and Power keys. When the Alcatel logo displays, release both keys. Use the Volume Up/Down keys to navigate to wipe data/factory reset.
To help you understand to perform factory reset for Nexa Corona 7 tablet, please follow the instructions given below:
- Make sure before performing factory reset, you take all the data backup from the tablet.
- Switch OFF the tablet completely.
- When it is completely switched OFF, press and hold 'POWER' and 'VOL+' together until you see a picture of the android robot lying on his back.
- Tap the 'Power' button once.
- You will see a menu, use 'VOL-' to move down in the 'Menu'.
- When you get to the 6th item (factory reset), press 'VOL+'.
- Do the same on the next screen to navigate to 'Yes' and wait for the time to finish the factory reset.
Actually you never mentioned make and model of your tablet, but probably you should try a Factory Reset.. The way to do a Factory Reset depend on make and model of your tablet, so try to be more specific.
You did not say which tablet you have. For Ideatab Android tablet, start with battery fully charged and tablet OFF. Press and hold Volume Up and Power at the same time until menu appears on screen. To navigate the menu, use Volume Down to move through the menu choices, Volume Up to select the current menu choice (like an Enter key) and Power button to return to previous menu. On the "Factory Menu", move down to "Clear eMMC" and select that option. You should see a message that data is being cleared. This may take several minutes to complete. Wait for it. When it completes, the tablet should be reset to the way it came from the factory so you will have to set up again user ids, wifi passwords, download apps, etc.
Usually that's when the battery is low but you may also be holding it down too long in frustration, It doe not treat that the same as a short press. Try a quicker one and wait.
