Music Logo
L
Larry Elkin Posted on Dec 20, 2014
I just bought a new Fender deluxe roadhouse Stratocaster. I get almost no sound out of the neck pickup and no out of phase sound with the pickup switch at the fourth position. I have tried adjusting the height of the neck pickup with no success. What am I missing?
TinMaN
Level 1:
New Friend:
  • Contributor 22 Answers
  • Posted on Dec 22, 2014
TinMaN
Contributor
Level 1:
New Friend:
Answers
22
Questions
Helped
4783
Points
59
Sounds like you're missing the guitar you paid for. Did you test the pick ups before you left the store or was it delivered? might be a bad weld. The wires might not be making full contact on to the connection of the pick up or the switch.
  • TinMaN
    TinMaN Dec 22, 2014
    If it's a Squire copy, That's your problem. I bought a Squire once. owned it for one night and during our usual weekend bonfires, I added my donation. It was worth it.
  • Painter33 Feb 16, 2015
    A "Squire" is definitely a copy, but a "Squier" can be a decent beginning or intermediate guitar. If you bought it at a guitar store, take it back to them for a proper setup that they should have done in the first place.
1helpful
Fender Squier Stratocaster serial number CY01084527. What year was it made and the value please?
Your squier guitar is from 2001
Says the last link. For value, check eBay sold listings.
Serial Number Lookup
Fender Guitars https://serialnumberlookup.fender.com Fender is proud to now offer self-service serial number search function. Feel free to bookmark the link for future reference, and please be aware that not every ...
Serial Number Tracking
Squier Wiki http://www.squierwiki.com > Serial-Number-Tracking
The serial number is printed on a sticker located on the back of the neck, close to where the neck attaches to the body. Because the number was placed on a ...
Squier Serial Number Lookup
Authority Guitar https://authorityguitar.com > squier-serial-number-loo...
Mar 8, 2023 - It's simple enough with our squier serial number Checker. Type your serial numbers into the decoder below and you'll get all the information ...
Squier Serial Check
Squier Serial Check http://guitarcheck.info Squier Guitar Check (1982 - 2011). Serial number. Serial Number should be 6-12 characters. Serial Number is required. Country of origin. Select Country, CHINA ...
1helpful
I bought a used black Fender Stratocaster about 20 years ago with the serial # H 035195 silkscreened on the headstock. At the base of the neck near the body, it has stamped " Made in USA".
I suspect the H is really an N, which would place it.1990-91. As long as the adjustment screw for the truss rod is at the base of the neck. The plugged top end isn't a concern. Your best source of info is to contact Fender customer service directly. Here's the link-
Contact Fender Musical Instruments Corporation
Woud you check fender serial number z6268670
Your guitar was made at the
Corona Plant (Fender), USA
in the Year(s): 2006 - 2007
I would like to know what year my fender stratocaster custom body guitar serial Number V033170 was Made and its aproximate value
This guitar is from the U.S. Vintage Series
made at the Corona Plant (Fender), USA
The Year cannot be determined from serial number.
However, you can remove your neck and check the date there.
Worth: $800- $1000
What year was a fender stratocaster serial number 33170 made?
in the Year(s): Cannot be determined from serial number,
however you can consult this chart showing the
corelation between serial numbers and dates found on the neck
Fender MIA RI Serial Number vs. Neck Date (Note the earliest I'm seeing is mid 80s)
When i move the selector switch to the middle position on my fender strat i get no sound. i get sound at the neck position
sounds like the wiring may have a short. your gonna have to use a meter to check continuity on each pickup to see where short is.
My 72' telecaster deluxe ri is great. but after doing some killswitching (turning the volume off the neck pickup) and switching between the bridge and middle possition quite fast, now it sticks and i have...
Oops you may have to replace the switch, it sounds like you have worn it out. You may be able to find a replacement on e-bay at a decent price or at your local Fender Dealer.
Aug 21, 2009 • Music
Top Fender Music Experts
Sean Wright
Sean Wright
Virgil Watts
Are you a Fender Music Expert? Answer questions, earn points and help others
