Poor signal strength is the bane of any receiver. See if you can improve matters by connecting your antenna to a good antenna amp and connect latter to your humax. Bet it works better. Also position as high as possible and direct it in the direction of most of the stations you want to receive.
make sure your tv aerial plugged in back of tv and your tv is on the dtv setting before trying to retune it. the sky box is usually on the scart or hdmi setting. hope this helps
This could be too much signal thanks to the Freeview retunes going on. Your aerial is more sensitive at some frequencies, so there's more signal power higher up the frequency range.
Loosing digital channels is equivlent to a snowy analog channel, check you cable connections, and splitters to the tv, since you have two of them out, it does not make sense that it is your tv. It is a conneciton in your cable line somewhere.
