It needs one of a few things
do this first
open the doors take all the food out
and move it /use it
and then defrost it doors open for a couple of days
now take out all the furniture inside it shelfs etc
so at the back of the freezer unit
is a panel it will have 4 or 6 screws or caps
you need to remove the caps/ screws clips
behind this panel is a fan and the freezer unit
perhaps the fan has failed
you can take the panel off
and check for an ice monster stopping it moving
so if there isnt one
power on and see the fan should spin up
if it doesnt the fan has failed {quite common}
so once you replace the fan with either a universal type
or a oem then it works the frost water ways its a V shape below
has a tube that connects this waist water to an evaporator tray mounted on the compresser at the base
so clean it all and the tube and dress it will salt
do the same for the drain on the fridge unit
and mount the back cleared of any debri about 5" from the wall and with good circulation
well you did ask whats up and how to fix it...!!
SOURCE: samsung rs2533sw fridge not cooling
it sounds like the refrigerator evap is frozen up causing the compartment to get too hot. shut the unit off and let it thaw out. then take the screws out of the cover to check the stryrofoam on the back side of the cover to see if theres broken spots on it causing the air to bypass the evap causing it to freeze. Theres two screws behind the light cover and two at the very bottom of the cover and two behind the decorative plugs about 1/2 way
soiunds like the coil on the refrigerator side is iced up.take and open the refrfigerator side and take a blow drier and after removing the 11 screws use the hair drier to slowly melt the icec behind the cover. If you pull too hard and or too soon you'll break the stryofoam ductin that has to be around the coil. then make sure that the drain line is clear reassemble and have a Merry Christmas!
SOURCE: Samsung RS2533SW refrigerator is not cooling.
It sounds like a defrost problem and I will help you if you need. Thanks, Sea Breeze
SOURCE: freezer side wont freeze
First thing to try is Powering off the FF at the mains supply and leaving it standing for 30 minutes. Make sure that you do not open any of the doors or touch any of the controls during this time. Then reconnect the power and wait for 30 to 60 minutes to see if the fault remains or is cured. Try completely defrosting the FF as despite common belief these units are not totally frost free.
If the Freezer and the Fridge are not cooling enough then check that the condenser is not iced up and that the fan is running correctly. These are located behind a panel in the lower half of the freezer at the rear and can be accessed from inside the freezer compartment.
In side by sides if the freezer side is working OK and the fridge side is not working correctly it means that air ducting from the condenser has iced up or the air vent from the freezing unit to the fridge compartment has stuck in the closed or partially closed position which causes the fridge to not be any where near as cool as it should be. If it is too cold then the vent is stuck in the open position and the fridge temperature will continue to fall and become the same as the freezer, thereby freezing the contents of the fridge compartment. It can also get stuck in another position so that if the temperature is adjusted on the front panel then nothing happens to the temperature in the fridge compartment. The vent, which is usually at the top of the fridge compartment on the side where it joins the freezer compartment, is controlled by a small sync motor and either the motor has become faulty, the control module is faulty or the vent is iced up. It can be come iced up by putting too many hot items in the fridge so the steam condenses and freezes the vent in position and then the motor cannot open or close it causing it and / or the control module to become faulty. Other times it is just old age that causes the motor and / or the control module to fail. If the sync motor and vent are working OK then there may be a fault with the fridge temperature sensor or main on board controller that will mean that the sensor or the controller will need replacing.
