The issue you are describing with your Saeco Exprelia Evo coffee machine, where it displays a "heating up" message and then restarts without any error message, could be caused by a few different issues. Here are a few things you can check:
Check the water tank: Make sure that the water tank is properly filled and that there are no blockages in the water supply line. If the water tank is empty or there is a blockage in the water supply line, the machine will not be able to heat up properly and will display a "refill water" message.
Check the brew group: Make sure that the brew group is properly seated and that there is no debris or blockages preventing the flow of water through the brew group. If the brew group is not properly seated or there is a blockage, the machine will not be able to heat up properly.
Check the heating element: Make sure that the heating element is functioning properly. If the heating element is not functioning properly, the machine will not be able to heat up.
Check the thermostat: Make sure that the thermostat is functioning properly. If the thermostat is not functioning properly, the machine will not be able to heat up properly.
Check the boiler pressure switch: Make sure that the boiler pressure switch is functioning properly. If the boiler pressure switch is not functioning properly, the machine will not be able to heat up.
If none of these steps resolve the issue, I would recommend contacting the manufacturer's customer support for further assistance. They may be able to provide additional troubleshooting steps or may recommend a qualified technician to repair the machine.
It's worth noting that these type of issues are usually caused by a malfunctioning component, and that attempting to fix it without proper knowledge could cause more damage and might void the warranty.
Check the power source: Make sure the clock is plugged in and that the outlet it is plugged into is functioning properly.
Check the fuse: If the clock is plugged in and the outlet is functioning properly, the issue may be with the fuse. Check the fuse to see if it has blown and replace it if necessary.
Check the temperature sensor: The temperature display may not be working if the temperature sensor is not functioning properly. Check the sensor to see if it is connected properly and test it to see if it is working. If the sensor is not functioning properly, you may need to replace it.
Check the wiring: If the power source, fuse, and temperature sensor are all functioning properly, the issue may be with the wiring. Check the wiring to see if it is properly connected and in good condition. If the wiring is damaged, you may need to replace it.
Properly tensioned new chains will require readjustment after a short 'break-in' period as they stretch. Some, improperly tensioned chains have long spots in them and they are difficult to properly adjust. All chains have a difficult life - even properly adjusted - properly lubricated - properly used (not abused). With a proper load (your weight) you should have about 3/4 inch play midway between the front and rear sprocket if your chain is properly adjusted. When properly adjusted and properly tightened, your chain should be checked weekly until you see no difference in the 3/4 inch. After that you should check the adjustment monthly throughout the life of the chain.
Just checking if your battery is fully charged, your coil is properly connected and ignition cables are properly seated and if you are still using carburator, the float are seating properly as not to flood the combustion chamber. The spark plugs are clean and properly gapped. I have found that if sprk plugs are not properly gapped at recommended gap, it may not give out sparks to burn compressed fuel.
Cheers. If you find this advise helpful, please give it a rating. Thanks
obviously the water pump was never fixed properly if it is still leaking, take it back to were you had it repaired and have them repair it properly. A number of problems could cause your vehicle to over heat. -water pump not working properly. -low antifreeze. -air lock. - rad cap not working properly. -thermos stat not working properly.
