Cooking Logo
Rexan Jone Posted on Dec 19, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Fruits which are big in size. All those fruits full of Hormones Is it true ?
john h
Level 3:
Top Expert:
  • Master 29,494 Answers
  • Posted on May 01, 2018
john h
Master
Level 3:
Top Expert:
Answers
29494
Questions
0
Helped
7559287
Points
193449
To much time on your hands --go online and search the fruits
Terry
Level 3:
  • Master 11,377 Answers
Terry
Master
Level 3:
Answers
11377
Questions
Helped
4625979
Points
152765
5 Related Answers
Sea Breeze
John Tripp
  • 4656 Answers
  • Posted on Jan 20, 2010
SOURCE: food (vegetables, fruits) on the refrigerater side freezing
Your model has a control damper inside the vent. The damper opens and closes with changes in temperature. It has a pig tail spiral thermostat on the side and if it goes bad the door sticks open or closed. Sometimes it is just frost but you will need to get to it. I will send photos and links in a moment, Thanks Sea Breeze
Anonymous
  • 126 Answers
  • Posted on Apr 24, 2010
SOURCE: My GE Profile Performer refrigerator is freezing fruits and veget
PUT THE REF. ON 5 AND SET THE
FREEZER ON 2 1/2 AND SEE IF THIS WORKS
Anonymous
  • 126 Answers
  • Posted on Apr 25, 2010
SOURCE: Fridge freezing everything
THIS REF. WORKS BEST WITH THE REF. SET ON 4 OR 5 AND THE FREEZER AT 2 1/2 OR 3. HAVING A HIGH FREEZER TEMPATURE CAN HAVE FREEZING IN THE BOTTOM DRAWER OF TH REF. MAINLY BECAUSE OF THE RETURN AIR VENT TO THE FREZER IS BEHIND THAT DRAWER.
Anonymous
  • 311 Answers
  • Posted on May 28, 2010
SOURCE: Crisper is freezing
This is a bad damper and it would need to be replaced. Try turning the freezer warmer until you can get this fixed and move up your stuff from the drawers.
Anonymous
  • 1099 Answers
  • Posted on Oct 31, 2010
SOURCE: My fruit and vegetable drawers
Hello, Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for.the air deflector....
As you know, the deflector directs the freezer air toward the front of the frig and the rear of the cold control I hope this will help....
tip
How to lose weight
<span> </span><span>By exercising daily you increase your metabolism, you keep your heart healthy and you increase your chances of reducing your weight.</span> <span><br /></span> <span>Several studies show that the amount of food you eat depends on the size of your plates. The bigger the plate the more food you will eat. There is a psychological connection between the size of the plate and the amount of food you eat regardless of how hungry you are.</span> <span><br /></span> <span>Reducing your food servings will help you lose weight but being selective on the foods you eat will help you lose weight faster.</span> <span><br /></span> <span>Research indicates that people who sleep less than 7 hours per day tend to accumulate more weight than people who sleep normally. There is a scientific logic behind this and has to do with hormones released during sleep.</span> <span><br /></span> <span>by removing the skin from chicken you can save up to 100 calories per normal piece.</span> <span><br /></span> <span>Many people tend to completely abandon their favorite foods from their diet especially when the foods carry a lot of calories. This is not recommended because eventually you will give up and eat those foods in larger quantities. You better keep them in your diet and have them as a 'reward' for achieving your weight loss goals.</span> <span><br /></span> <span>They say that 'Prevention is always the best cure', and this is true for weight loss as well. Instead of being tempted you better save yourself from the trouble and remove any junk food, sweets, full fat foods and drinks from your kitchen and fridge. Instead replace those foods with fresh fruits and vegetables.</span>
on Jun 29, 2011 • Exercise & Fitness
Top Cooking Experts
Billie Aukuso
ADMIN Andrew
ADMIN Andrew
Are you a Cooking Expert? Answer questions, earn points and help others
