Boating Logo
Robert Huddleston Posted on Dec 19, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Could you please tell me the transom angle on a 2006 lund,SSV 14,need to know,to mount a transducer correctly.thanks
Craig Vohwinkle
Level 2:
Scholar:
New Friend:
  • Expert 97 Answers
  • Posted on Dec 25, 2014
Craig Vohwinkle
Expert
Level 2:
Scholar:
New Friend:
Answers
97
Questions
Helped
37963
Points
215
Don't over think this. Mount your transducer so it will set parallel to the lake bottom when the boat is in the water. If your off by a degree or two it will not affect your sonar performance. The human eye can measure differences in angle down to about 1/10th of an inch. "Eyeball it" and you will be good to go.
5 Related Answers
Anonymous
  • 8 Answers
  • Posted on Nov 28, 2008
SOURCE: remove pin pivot in transom mount
look for clips around the pin inside the housing perimiter. If you see rings cut in the pin that don't have clips in them, they probably fell off. If used in a marine environment, the pin probably is corroded and locked to the housing. Use usual methods, i.e. heat and lube and.....a hammer wrench.
Anonymous
  • 10 Answers
  • Posted on May 08, 2009
SOURCE: bow mount 80lb to transom mount
Parts can be purchased from this dealer...There are schematics on the site for review....
http://www.northlandmarine.com/MinnKotaQuickRef.htm
Editor925
Dean
  • 285 Answers
  • Posted on May 29, 2009
SOURCE: lorance x25 and x48 configuration, same transducer imput to unit?
The answer is yes. The transducer will fit both units fine without any modification.
See http://primus.lowrance.com/support/resultDisplay.do?docType=1000&contextId=17%3A10.34&clusterName=ClusterPublic&docset=%2FDocuments%2FAccessories&linktosource=1&responseId=135ccbe2cfd4f608%3Adcb03b%3A1218e166f10%3A-5e14&groupId=4&answerGroup=4&score=984&page=http%3A%2F%2Fprimus.lowrance.com%2Ficr%2FAccessories%2FTransducer+Compatibility-Black-192khz.htm&result=5&excerpt=Transducer+Compatibility&resultType=5000#Goto10 for confirmation.
Please rate this solution on FixYa!
dnewcombe1
Dana Newcombe
  • 1564 Answers
  • Posted on Sep 07, 2009
SOURCE: I have an Eagle Fisheasy fish finder & need to replace transducer
You can find out which one is serving the device you wish to repair by waving a small spade or wide metal object about a foot from each of the existing transducers and have someone else monitoring the insruments on the concole.
Kevin Gens
  • 64 Answers
  • Posted on Sep 07, 2010
SOURCE: Have just installed a Garmin 140 on a tracker
I would recommend having the back part of the transducer a little higher (toward the sky) than the nose of the transducer. When I say a little, I mean a very slightly. This way the nose of the transducer pushes the water and any bubbles away from the face.
93 bayliner 2252 transom angle
you might want to post this in the boat section
Transducer is throwing up a large Rooster tail.I installed it to instructions
Might help to tell us what kind of boat - deep V hull 22 ft.? bass boat with shallow V hull? Some need the transducer closer to the centerline of the vessel while others do better more outboard, Naturally they need to be flush with the hull no matter where they are located. Depending on the transducer, you could also try properly mounting it inside the vessel near the transom. Good new is you are getting good info from it. Cheers Pete
Hi I live in NZ and have a Humminbird 383c GPS Chartplottter which was purchased in the US. approx 2 years ago.It has a transom mounted transducer which I mounted in a piece of plastic pipe, epoxied in the...
Don,
We would recommend that you replace the transducer (if you want to keep the transducer inside the hull you may use the
XP 9 20 T with temperature and you can use epoxy to mount the transducer) If you want to keep in the compartment you have created you may want to just put water in the compartment with the transducer so its not shooting through the air.
If you have any other questions please email customer service at [email protected]
Thank you,
Deborah
Humminbird Customer Service
Hi. Just wondering how should the transducer for my humminbird 525 fish finder/sounder be installed correctly? Thanks
You can take a picture of the transom of your boat and email it to Humminbird and they will email it back to you where the transducer should be mounted at. Our email address is [email protected].
Joby @ Humminbird
My problem is I bought a 600l furuno and it came w/a thru-hull transducer and I wanted a transom mounted trans.I all ready bought a tr/mount and I need to sell the thru/hull.It's the 2" w/speed and temp...
i will exchange this for you, free shipping no charge, just ship it to me to inspect and i will send you the transom ducer no charge, if you have a bronze thru hull with speed and temp to trade for a plastic transom mount with speed and temp, let me know
I have lowrance 337 c gps combo, I have a lund baron i/o aluminun boat. When the boat is running i get alot of interference on the screen. I tried running the power cord for the graph direct to the...
You can use a thru-hull transducer but a transom mount transducer will always interference with all of that water and alot of air bubbles moving under it at high speeds.
Jul 16, 2009 • Boating
4answers
Hi I have an Apelco 530 fishfinder/gps and need a through hull transducer kit. Apelco were taken out by Raymarine who advised me to contact Airmar who made the transducers. So far no answer but their...
Embedded
I was looking to see if I could find a replacement for the display and was able to confirm that the transducer is a single beam 120khz unit so I doubt that you've find a replacement for it ..as is .
The Airmar C-49 is the proper number for the connection line but like me I think your going to have to think about a whole new unit and or system . Been there already.
Best of luck.
Sir Isaac
Top Boating Experts
ADMIN Andrew
ADMIN Andrew
jws1013
Kardoc
Are you a Boating Expert? Answer questions, earn points and help others
