Rothco Maglight 3-D Cell LED Flashlight - Black Logo
S
Steven Ruoff Posted on Dec 19, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Maglight fades to off after 5 seconds
Checked batteries - good, bulb works fine for 5 seconds and then fades quickly
Mikey
Level 3:
Top Expert:
  • Master 6,904 Answers
  • Posted on Dec 19, 2014
 Mikey
Master
Level 3:
Top Expert:
Answers
6904
Questions
5
Helped
1623401
Points
26106
Has this just happened after working ok? Is this a new maglight? Have you tried brand new batteries? Have you checked metal contacts to the batteries?
How do you replace the LED bulb in a AA cell maglight flashlight
question is in TV section--answer would be contact Maglight to see if the part is even available and if not buy another flashlight.
How do I remove batteries that are corroded in a 3 "d" cell maglight?
I would find out the battery brand, leave the batteries in the re, and ship the whole thing back to duracell for a new flash light and a bunch of batteries. They always replace anything their batteries destroy, and they are good about it. I had a maglight that I couldn't get the batteries out of, and got a brand new one, and a bunch of batteries. Hope this helps.
Dell Laptop Inspiron 1525, boots up but once booted the screen only stays bright for a few seconds - a minute and the it seems to fade/ become very dim, you can barely see the windows behind it. This only...
Theres a good chance that you have a power settings problem.
goto:
control panel / power options / power schemes
and make sure you dont have quick time out for ac or battery.
even it if looks right, change both. and reboot see if helps
Indicators Flashing Too Quickly
Check there are no faulty bulbs on the indicator circuits, and that all bulbs are of the correct wattage.
(Water in a lamp connector can also cause erratic indicator operation due electrolysis/corrosion).
Check alternator running / battery operating voltage does not exceed 14.5V.
Turn indicator light flashes quickly. bulbs fine
The quick flash is a fault detection for a burnt out bulb. If bulb is good, check bulb socket. Inspect for corrosion. If needed, replace bulb socket. Check bulb socket connector. Check if fuse. Check emergency flashers ( most cars have a separate circuit).
20helpful
4answers
How do I replace battery?
I had the same problem... the battery is part # 501235 and is 3.7v 150 mah (yes, it's tiny). Searching for this on the web yields such a part at various places but not any retail options that I could find.
I took it apart per the instructions at instructables.com (above) and then jump-started the battery using a maglight penlight. Sometimes rechargeable batteries get "stuck" on empty when they drain down to absolute zero and have trouble accepting any charge... To jumpstart it, do this:
Get a Maglight AAA or AA penlight (2 cell) and unscrew the end as if you were going to replace the light bulb. The bare bulb must be on when the reflector is removed (or, perhaps the batteries are dead).
Remove the bulb.
Obtain two short (1") pieces of bare 22-26AWG wire and insert them into the holes where the bulb wires were previously inserted.
Using a multimeter, determine which wire is positive and which is negative
Align the + terminal of the rechargeable battery in the Jabra with the positive wire identified on the flashlight - do the same with the negative terminal. Hold the flashlight on the battery for a minute or so to allow some of the current from the light to slightly charge the jabra battery.
Before putting the Jabra back together, try the AC or USB power cord - you should now get a solid red light if it is charging.
If not, try to "jump" it again for another minute or two or three.
If this doesn't work, the battery is probably totally shot - maybe you'll have better luck finding a replacement than I did.
The Maglight isn't necessary, but it is a simple way to obtain the 3.0v DC power source. You could use a similar power source to obtain the same effect (probably 2.7-3.7v DC is best).
Top Rothco Camping, Backpacking & Hiking Experts
ADMIN Andrew
ADMIN Andrew
Kardoc
Are you a Rothco Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
