Installing PrintMaster 18 on any computer requires .NET Framework 1.1 to be installed on the hard drive. If NET Framework 1.1 is not installed, it will be installed from thePrintMaster 18 install disk before PrintMaster 18 is installed.
If possible download .NET framework 1.1
If .NET Framework 1.1 is not already installed on the computer, the "Program Compatibility Assistant" in Windows 7 will display this message.To continue with the installation, select "Run Program".
Unfortunately, the 'New' PrintMaster 2011 will not import any older PrintMaster .sig files created prior to PrintMaster 2.0. This means that over 1,100 projects I have,going back to 2004 are now useless. Did they even consider this before coming out with the new version? Is this the way that Broderbund treats long time customers of their product? Apparently so...so I will no longer be using any of their products from now on. I don't see any excuse for their actions.
In this instance it is easier to direct you to a video on the "Microsoft" website regarding installing older programmes. This is much clearer than trying to explain in writing.
You can install this and then run it in compatibility mode by right-clicking the programs icon. Usually anything that worked with XP will run in this mode with Win 7.
this is more than likely an issue witht the disc that the file is located on. I would contact the manufacturer and see if there is any way to get a replacement disc.
I understand that you are inquiring if Printmaster 18 is compatible with Windows 7. Our developers have tested every aspect of Printmaster 18 to see if it will function properly on Windows 7. It has passed all tests except one, which is the Save As PDF feature. Our developers just became aware of this and are working on a resolution to make it work on the Windows 7 operating system. We apologize for any inconvenience this has caused, but we can assure you that we will provide a fix for this as soon as possible.
How do you do. For decision of your problem advise you to change adjusting the printer. There is adjusting the seal In characteristic of the printer. You it is necessary to install seal the text.Thank you for question.
