are they washing rags or mop heads that leave stringy fibers on the screen ?are they washing rags or mop heads that leave stringy fibers on the screen ?
You can't post conmments that contain an email address.
1.Loss of water pressure due to pump obstruction. Check for any obstruction at the pump intake.
2.Strainers clogged causing inadequate water supply to pump.
3.something may be inhibiting free movement of the low water float; remove any foreign object from around the low water float or its magnet.
Hi You may need to pull strainer out and clean basket better, check interior aspects of strainer housing to see if build up of any kind is blocking sensor contacts of strainer.
Possible:
1. Dirty line strainer, causing low water pressure/flow. Turn off the water supply to the dishwaher, open the strainer cap, and clean the screen.
2. Low water pressure
3. Excessive Lime or mineral deposits in the wash/rinse system. You may need to delime the system.
4. Water temperature is below 110 degrees.
5. If equipped with a booster (heater), and more than 8 minutes pass with the water temp still below 110 degrees. Heater may be bad.
Unless you have a special purpose sink all basket strainers are standard size. You should be able to use strainer from any manufacturer that has the color that you want. If you are doing this yourself make sure you use rubber gasket and fiber friction ring. These go on the underside of sink in between sink bottom and retaing nut. I would recommend you use a small amount of pure silicone caulking in between flange of strainer and sink surface. Be ready to wipe off excess caulking as soon as you get retaing nut snug as it starts to cure in about ten mins. I use paper towels and wipe till its clean. Hope this helps. Thanks
Try cleaning your strainer. It is located behind the kick panel below the front main panel. It is connected to the drum with a rubber hose, and attached to the pump. Pull the strainer cover and remove the strainer. While the strainer is open, look up into the pump cavity for any other loose debris, and remove it.
Best regards, --W/D--
I had the same problem.....The start/pause button would flash during a cycle and the washer would not finish the cycle. After reading on this forum that there is a filter/strainer inline with the drain, I tried this solution.
Remove the (3) screws that hold the lower front panel (Just below the door)
Once the panel is removed, you should see a white plastic strainer hooked to the washer drain.
Please a large bowl under the opening and unscrew the knob/handle, pull the filter/strainer out and clean all of the lint/trash out of this area.
My filter/strainer was clogged with a baby sock, 2 doilies, a fewe pennies, 2 dimes and lot's of lint.
I believe all of this debris was causing musty odors in the machine as the lint would stink due to dampness.
Once I cleared out this filter/strainer the problem and my odors went away
I wish GE would add this "EASY" step into the owners manual for proper care and maintenace.
Thank you for letting me know about this filter/strainer as it did resolve my problem
