I seem to have driver but it won't send jobs to printer. maybe wrong IP address? How do I find correct address for my machine?
Robert, C-252 Copier prefers that you give it a IP address (Call Static IP) Do not use DHCP which the network determines .
Go Administrator, Admin One Network TCP/IP have your network administrator determine best IP address for your network.to give the copier
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: konica minolta bizhub C252 printer Problem
Is anyone else having problems getting Konica to stand behind its products.
SOURCE: Problem in configuring IP address in Konica Minolta bizhub 210 Copier, Printer, Fax
Is there network card is installed in it, if yes then you can configure it with your network go to machine Manu in machine control panel and the in network settings here you can give the IP address and subnet mask after then reboot the machine.
If network card is no installed behind the machine then you can use its built-in USB or and parallel printer without NIC card.
SOURCE: getting the ip address
To print out machine current ip address, go to utilities, user setting, printer setting, print reports, configuration.
It is supported for Vista according to this chart
Here is the drivers for 32 bit Vista
SOURCE: Question about Konica Minolta Bizhub 350
click here for the steps on how to configure the bizhub 350 and here for the vista driver that you need to use if you're going to install it in a vista computer
hope this'll help you
ciao
