Sony Vertical iPod micro system CMTLX20I Remote Control Logo
a
alfred semanyk Posted on Dec 17, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Set time on sonymp3 cmt-bx20i - Sony Vertical iPod micro system CMTLX20I Remote Control
The Jed
Level 2:
Scholar:
  • Expert 42 Answers
  • Posted on Dec 21, 2014
The Jed
Expert
Level 2:
Scholar:
Answers
42
Questions
0
Helped
29498
Points
145
You need to use buttons on the remote to set the clock.
1.Turn on the system.
2.To select the clock set mode press TIMER MENU. If the current mode appears on the display, press up and/or down to select
"CLOCK SET?" and then press (+)
3.To set the time. Press up and/or down to set the hour, and then press (+) to confirm. Repeat to set minutes.
The clock needs to be re-set whenever power is lost to the unit.
The clock can be momentarily displayed when the system is off by pressing DISPLAY. The clock is then displayed for about 8
seconds.
The full support section with manual downloads is available here for further help and guidance:
http://esupport.sony.com/US/p/model-home.pl?mdl=CMTBX20I
Hope this is of help.
2helpful
I can't turn demo mode off or Standby from flashing on my Sony CMT-MX550i, can't turn unit off without unplugging it.
Sony CMT-MX550i -- I had good results by pressing the "TIMER MENU" button on the remote and simply setting the time. After that, no more demo.
Wont stay on
main board needs to be replaced. Probably a short in the amp
Flyback no. of cmt 2198
The B+ of your CMT 2198 TV seems to be about 95V.
• Have a time to read about these tip:
How to test Flyback Transformer Without taking it off the Board
While we search for your flyback transformer T751 part number
we will let you know.. .
Hello i have a problem with my nokia 3110c whitch is : when i flash my phone with phoenix i got this result : Flashing started Creating product data items list Product data items list created Backup...
Now what is the condition of the phone ? If the phone has still problem, uninstall the previous file you have installed and re-install this one3110c file.Select the product code 0544311 or 0556977.This two files can use universal.Use fully charge battery or insert charger when message prompt.I hope there will be no error.Thanks good luck.
Hi, the cd player for this Sony system works fine with most of my cds. However, some of my older ones and burned ones don't produce any sound. The system recognizes the cd's cause I can skip tracks and see...
The only audio formats supported by the CMT-BX20i are "CD-DA and MP3". When DVDs were first getting started, they didn't have standardized audio and video formats. The burned videos are likely AC3. For both your old and burned DVDs, you can convert them on your computer with an audio video program like Nero or DVD Videosoft.
Sony CMT-BX20i the cd player won't read any of my CDs? What can I do to fix this?
hello, have you tried cleaning the laser you can buy a disc cleaner or you can do it by hand. with the power off take the cover off you see another plastic cover take this off you should be able to see the laser eye use a cotton bud with either a proper cd lens cleaner or nailviarnish remover if this does not solve the problem then theres a fault with the laser fingers crossed
regards
shaun
2helpful
I want boot i.c jumper plz
1ST BOOT : C0,07 [Rm-237] [2.1.0.1]
RAPx ID : 000000010000022600010006010C192101001101
EM 1 ID : 00000232
EM 2 ID : 00000353
RAPx PBID : 25F0000B448F7C56DB6F0376EB3436C5CB38F97F
RAPx MODE : 00
RAPx HASH : BAF3A9C3DBFA8454937DB77F2B8852B1
RAPx ROID : 191EC665DFAAF68F
CMT 1ST Boot OK
CMT 2ND Bt: RAP3Gv3_2nd.fg, Ver: 9.11.1
CMT FLID0 : 00898981-00006A21, Int NU48F256
CMT FLCNT : 00000000000000000000000000000000000000
CMT MCID0 : FFFF0000-00000000
CMT 2ND Boot OK
CMT ALGO : RAP3Gv3_algo_v1331.fg, Ver: 1.33.1
CMT VPP : Internal
DUAL LINE : True
CMT ALG Boot OK
INFO_2ND : APE Chip Absent
INFO_ALG : APE Chip Absent
PASUBTOC not Exists
Rebooting Mobile
Feb 27, 2010 • Nokia 6600
2helpful
Sony CD/Radio CMT-EP505: Setting fixed radio stations
Click Sony Support to download instruction manual copy of CMT-EP505 that has operation details of every thing in this system.
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
