I ALREADY DELETE SOME DATA OR IMAGE BUT STILL NOT ENOUGH MEMORY TO PERFORM THE OPERATION APPEAR...
SOURCE: problem coping songs from phone memory to mmc
the best way for this phoen is to get a data cable and when it is plugged into your computet click and dragg the songs that you want from the phone folder to the memory card.
SOURCE: NOT ENOUGH MEMORY TO PERFORM OPERATION.DELETE SOME DATA FIRST"
I think you installed the virus in phone. You need to hard reset your phone. Back up your data on your phone e.g. contacts, tones, images and videos.
WARNING ALL DATA ON YOUR PHONE WILL BE ERASE.
Here’s how to hard reset or format your Nokia N70 mobile phone:
1) Switch off your phone
2) Press and hold these 3 keys together:
-green dial key
-the star key(*)
-the number 3 key (Ugh, I wish I had three hands…!!)
3) Power on the phone
Warning: Do not release the keys until you see the hand animation is displayed.
SOURCE: memory low n70
You need to change default storage device on your phone, from phone memry to card memory. In other words, move all data (messages, songs, videos etc) from your phone memory to card memory.
for example, go to messages>options>other>momory in use - change it to memory card instead of phone. (if your memory card is not named, it will be displayed as NO NAME).
Do the same with other data also.
SOURCE: music memorynot enough memory to perform delete some data
i have problem with nokia n72 plz solve the problem
SOURCE: Music Player: Not enough memory to perform operation delete some data first
nthing to worry change ur message setting ,put memory card memory as memory in use. after cahnging tht u cn easily save ur files to ur memory card
