Have changed the toner but still call for service.
SOURCE: Our bizhub-250 receives a C2557
hi,
open and close front door cover to reset error.
If it persists you have to execute (TCR Toner SUPPLY)
Tell me if you need to execute it.
Bye.
SOURCE: Minolta bizhub c 351 code c 3451
If you go into tech mode-system1- initialization-system error clear-press start and reboot.
SOURCE: Malfunction(Code 3451) of Bizhub C252
This is a fuser heat error. The fuser unit is located in the area where the paper exits the machine. It heats up and "fuses" the toner onto the paper. The error code means that it did not heat up properly. This means you will most likely need a service person to come out and diagnose the problem.
You can try to reset the error but I doubt it will help.
Turn off the MAIN power switch (not the one on the control panel)
Now hold down the utility key while turning on the main switch and continue holding the utility key for at least 10 seconds. You should see a screen come up with nothing but "trouble reset"
Touch trouble reset and you should see a small "ok" come on. Then turn off then on the main switch again.
Good Luck and Thank You for using Fixya.
SOURCE: konika minolta bizhub 350 Error c3451
Hi there.
Try this It could do the trick for you.
The error code c3451 refers to a copier warm up error; the machine had not reached the correct temp within a specific time.
I bet it happened when you first switched on one morning.
Easy to reset and fault usually goes away.
To Reset switch machine off using the switch inside the front door, not the one on the control panel.
Whilst holding the UTILITY key down on the control panel switch the machine back on keeping the UTILITY key held down. Eventually a Trouble reset key will be displayed in the LCD screen, touch this, OK will be displayed then power the machine off and then back on.
This will reset the error code, if the code reoccurs then there will be a problem with the fuser unit in the machine, and this will require replacing.
Hope it did work for you.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
