LIGHTS WILL NOT WORK. TRIED REPLACING BULBS..STILL DON'T WORK. WHAT COULD BE THE PROBLEM?
Take the bulb back out and check to see if the prong that hits the bottom of the light bulb is making contact. If that don't work then its most likely going to be a short or a wire problem of some sort...Do all the basics first the work your way down...It should be to hard if your willing to go further if necessary...If not then its time to call the tech...Hope this helps you out..
