Washing Machines Logo
m
mark Posted on Dec 16, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a whirlpool washer (Heavy Duty Super Capacity Plus) that will agitate and drain but won't spin in the spin cycle. I was able to get it spinning by opening the lid and helping it along by spinni
Spinning by hand, then it was empty, and it worked, then stop by it self.
wa2yyx
Level 2:
Sergeant:
Champion:
  • Expert 282 Answers
  • Posted on Dec 16, 2014
wa2yyx
Expert
Level 2:
Sergeant:
Champion:
Answers
282
Questions
0
Helped
70484
Points
590
Sounds like it could be the belt or transmission
Testimonial: "what makes you say that?"
  • wa2yyx Dec 17, 2014
    If it goes when you try to spin it then it sounds logical that the belt may be slipping or the transmission is having problems with the clutches
4helpful
6helpful
2answers
Whirlpool heavy duty super capacity plus washer will not agitate or spin. I replaced the agitator dogs but still have the same problem, is this a transmission issue?
Your model may have a flexible (break able) drive component between the motor and the transmission. Check that, it is a pretty easy replacement.
3answers
I have a Whirlpool Heavy Duty-Super Capacity Plus, 7cycle/2 speed. Model LSR7200EQO , the agitator stopped working
My whirlpool heavy duty 2 speed 7 cycle washer machine stopped working, It fills up and aggitates for the first cycle then when it should drain and spin it doesnt drain nor spin
Little AGITATION clothes not getting clean, Spin cycle is fine
Hi Sherrie,
There is a service manual located inside the front left side of the cabinet.I find it easier to turn the washer on it's back and then reach up in the cabinet to get it.Hope this Helps !
2helpful
Old Washer won't spin or agitate
You found a belt? Most w/p washer do not have a belt they are direct drive. take off the pump and motor to replace the motor coupling, 2 plastic pieces w/ a rubber in between
1helpful
Whirpool lsq9244eqo fills and drains but does not spin or agitate
It sounds like the agitator gripping teeth are worn out. To check this, take the agitator cap off with a strong knife or flat-head screw driver, pull the cap off and check the plastice teeth and four plastic hooks that grab the teeth. If they are worn out, then you will have to replace the agitator. To replace it, you will see a nut that is between the circlular teeth. Unscrew the nut and pull the agitator up hard.
2helpful
Washer spin & gurtitate no working
Coupling is broken that connects motor to transmission. Replace it. Please contact me if you need further help or leave feedback if appropriate as that is how I get paid. Thanks for letting me help you!
5helpful
Won't spin or agitate
coupling.between motor and gearcase.
10helpful
2answers
Agitator
if its a 2 piece agitator.. the gears in top of agitator is stripped out.. change gears be like new....spin top countor clockwise if it dont grap.. gears bad
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
