Question about Liebert Corp GXT3 10000VA 230V RACK TOWER
How to correct fault with Liebert GXT3-10000RT230?
Indicators that are illuminated: - Fault, - Bypass, - diagnostic A and D indicators.
2 Suggested Answers
SOURCE:
SOURCE: Help with my liebert powersure interactive 1000?
Get an outlet tester. See http://www.acmehowto.com/howto/homemaintenance/electrical/outlettest.php
The tester will tell you what is wrong with the outlet.
Posted on Mar 19, 2008
I have a whirlpool cabrio and the lid will not lock the light keeps flashing and it keeps making the lock clicking sound
BEFORE ASSUMING THE LID SWITCH NEEDS REPLACEMENT TEST WITH A METER, BUT FIRST TRY TO RESET CONTROL BOARD EVEN RUNNING A DIAGNOSTIC TEST WILL REVEAL THE SOURCE OF THE ERROR.. 1. Be sure the washer is in standby mode (plugged in with all indicators off; or with only the Clothes Clean or Done indicator on). 2. Select any one button (except POWER, START, STOP, and PAUSE/CANCEL) and follow the steps below, using the same button: a. Press/hold 3 seconds. b. Release for 3 seconds. c. Press/hold 3 seconds. d. Release for 3 seconds. e. Press/hold 3 seconds. ? If this test mode has been entered successfully, all indicators on the console are illuminated for 5 seconds with 88 showing in the Estimated Time Remaining two-digit display. ? If indicators do not display as described above, the press/hold/release procedure above may not have been performed within the time frame necessary for successful entry. Repeat step 2 to ensure this was not the cause. If still unsuccessful, see Diagnostic: Unsuccessful Entry, at right. 3. The test sequence continues by checking for saved fault codes: ? If there are saved fault codes, see Diagnostic: Saved Fault Codes, page 2. ? If there are no saved fault codes, all indicators on the console will momentarily turn off, then turn back on with 88 displayed. After 5 seconds, the Automatic test, below, begins.
http://www.applianceaid.com/pdf/Whirlpool-Cabrio-Waher-WTW6600SB3-Tech-Sheet-W10026634.pdf
TEST #8 Lid Lock Perform the following checks if washer fails to lock (or unlock). 1. Perform Manual: Lid Switch and Manual: Lid Lock tests on page 2. 2. Remove the console to access the machine/motor control assembly. See Accessing & Removing the Electronic Assemblies, at right. 3. Visually check that the P12 connector is inserted all the way into the machine/motor control. ? If visual check passes, go to step 4. ? If visual check fails, reconnect P4 and repeat step 1. 4. Check the lid lock motor winding and switches by removing P12 from the machine/motor control and checking the resistance values shown in the following Lid Lock Resistance table:
TO RESET TURN KNOB 1 FULL TURN COUNTERCLOCKWISE, THEN 3 TURNS OR CLICKS CLOCKWISE, 1 TURN COUNTER CLOCKWISE, 1 MORE TURN CLOCKWISE, THEN HIT START , ALL THE INDICATOR LIGHTS SHOULD THEN LIGHT UP, THEN UNPLUG FROM THE WALL FOR 5 MINUTES THEN PLUG BACK IN , IT SHOULD BE RESET AFTER PLUGGING BACK IN
Feb 11, 2017 | Whirlpool Washing Machines
Why does check engine light blink when I accelerate?
Hi Ced ,
The malfunction indicator lamp (MIL) is located in the instrument panel cluster. The MIL will display as either SERVICE ENGINE SOON or one of the following symbols when commanded ON:
Check engine ! The MIL indicates that an emissions related fault has occurred and vehicle service is required.
The following is a list of the modes of operation for the MIL:
The MIL illuminates when the ignition is turned ON, with the engine OFF. This is a bulb test to ensure the MIL is able to illuminate.
The MIL turns OFF after the engine is started if a diagnostic fault is not present.
The MIL remains illuminated after the engine is started if the control module detects a fault. A diagnostic trouble code (DTC) is stored any time the control module illuminates the MIL due to an emissions related fault. The MIL turns OFF after three consecutive ignition cycles in which a Test Passed has been reported for the diagnostic test that originally caused the MIL to illuminate.
The MIL flashes if the control module detects a misfire condition which could damage the catalytic converter.
When the MIL is illuminated and the engine stalls, the MIL will remain illuminated as long as the ignition is ON.
When the MIL is not illuminated and the engine stalls, the MIL will not illuminate until the ignition is cycled OFF and then ON.
Trip
Mar 13, 2015 | 2003 Chevrolet Impala
Liebert gxt2-10000rt208 fault indicator and A + E LEDs on. Did anyone know this alarm?
I'm going to go on a limb and say the unit also has the bypass indicator on as well, is that correct? A=On bypass due to overtemperature condition & E=On bypass due to inverter failure.
I can't see in the picture or hear it but is it beeping also? 1 second beep every 2 seconds? Thats on internal bypass. If none of this is true then you have a tricky problem.
Dec 09, 2014 | Liebert Computers & Internet
Liebert gxt2-10000t230 low batt,bypass light flashing,no output,shutdown after a minute
Test outlet power by switching the unit to manual bypass and breakers off.
If power is supplied OK and the filter board repaired OK then restart the unit starting with the breakers supply to unit,battery confirm the display is on and static bypass led also on then switch back the bypass knob to normal and press the on button to switch the unit to normal.
Give the batteries time to charge 12hours then you can test the unit on backup mode.
Nov 25, 2014 | Liebert (GXT2-10000T230) (GXT2-10000T230)...
How to correct fault on liebert gxt3?
Disconnect batteries. Shut off the UPS wait 5 min. If alarms returns then something is wrong with your unit
Aug 18, 2014 | Liebert UPStation GXT2700RT-208...
Why software for clear fault on liebert ups nx 40 kva
The software allows you access the battery life monitor and reset it. It is the only way to clear the fault
Apr 29, 2014 | Liebert Computers & Internet
Machine powers up,,,than the whole machines powers down
Let's see if we can get it into diagnostic mode and check for any fault codes. Make sure the dryer is in standby mode, plugged in with all the indicators off. Select any button except the PAUSE/CANCEL button. PRESS/HOLD 3 SECONDS > RELEASE FOR 3 SECONDS > PRESS/HOLD 3 SECONDS > RELEASE FOR 3 SECONDS > PRESS/HOLD 3 SECONDS. If test mode was entered successfully all indicators will illuminate for 5 seconds with 88 showing in the two digit display. If there are no saved or active fault codes all indicators will momentarily turn off then stay on with 88 in the display. If there are any fault codes, the most recent one will alternately show F- and "XX " where XX is the fault code. and all the cycle indicators will flash. If you can't enter the test mode try a different button. Lets start there.
Nov 17, 2012 | Whirlpool Duet Sport HT WFW8400TE Washer
After battery replacement, upon power up, constant beep with fault light full on and battery light flashing. On some trys, the bypass light will also light up. No response from buttons. Unit is...
Try and push and hold the on button for about 3 sec. This will start a manual battery test. If only three of the five battery led illuminate allow the ups to recharge the batteries for 24 hours. Battery light flashing means internal battery source not available. Check battery connection, completely power down and reboot UPS
Sep 06, 2011 | Liebert UPStation GXT1000RT...
My cabrio wtw6200sw2 has F50 code and won't spin I can't seem to find out what the code means. Could it be the motor coupler or controller board?
The F50 code for the Whirlpool Cabrio is most commonly a Motor Control Board failure.
Motor Stalled
F then 50 flashes when the motor rotor position sensor (RPS) senses no rotation.
? Does basket turn freely? If not, make sure bottom shipping pack has been removed. Determine cause of friction.
? If basket turns freely, see TEST #3, page 4 of the Diagnostics and Repair manual.
The Diagnostics and Repair manual can be downloaded as a PDF document file here:
http://www.mediafire.com/?np4yufblj33c0xm
DIAGNOSTIC TESTS
There are three diagnostic test modes available: Automatic, Manual and Console. These tests allow the factory or service personnel to test and verify all inputs to the machine/motor control. You may want to allow the automatic test cycle to complete prior to going into specific troubleshooting tests.
ACTIVATION OF AUTOMATIC DIAGNOSTIC TEST MODE
  2. Select any one button (except POWER, START, STOP and PAUSE/CANCEL) and follow the steps below, using the same button (remember the button):
  • Press/hold 3 seconds.
  • Release for 3 seconds.
  • If this test mode has been entered successfully, all indicators on the console are illuminated for 5 seconds with 88 showing in the Estimated Time Remaining two-digit display.
  • If indicators do not display as described above, the press/hold/release procedure above may not have been performed within the time frame necessary for successful entry. Repeat step 2 to ensure this was not the cause.
  • If still unsuccessful, see Diagnostic: Unsuccessful Entry.
  1. The program then checks for saved fault codes:
DIAGNOSTIC: Automatic
Performs a five-minute automatic test with water functions to check major washer functions (door can be open). Press the same button used in step 2 above to advance through automatic test steps.
NOTE: Basket must be floating in order to agitate.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Feb 01, 2011 | Whirlpool WTW6400SW Cabrio Washer
My indicators have stopped working also the heater
If the the indicator light's illuminate ,when turned on ,the signal flasher is at fault .
Replace it.
Mar 07, 2010 | 1991 Peugeot 405
Liebert Corp GXT3 10000VA 230V RACK TOWER Logo
473 people viewed this question
Top Liebert Water Sport Experts
Marvin
Marvin
Bill Boyd
Tom Chichester
Are you a Liebert Water Sport Expert? Answer questions, earn points and help others
