I have cleaned the charge, transfer, detack coronas, has a new drum. Cleaned image head.
Well, well, this machine was my bread and butter for years.
The black edge could be caused by the developer being U/S original life approxmatly 9 months, or an over concentrated toner / developer mix. That would need setting up again. You'll need a manual for that, or a visit from the local Xerox engineer. Do you have a wide format scanner to go with that system? Does the black edge only occur with a copy or a direct print from your CAD system?
SOURCE: Fuzzy Pages
In your troubleshootine menu, I think it is, on the screen, scroll until you find fix imaging problems, or something like that.
There is one for removing streaks and the other for removing smudges.
I would suggest running both and that should resolve your issue.
I doubt your maintence kit is bad, but I would pull it out and check to see if it is extremelty dirty.
Try those two procedures first.
There will be instructions on your User Guide CD on how to run those.
SOURCE: Xerox Phaser 8500 not printing black
Here are the directions to enable and disable Jet Substitution. This may very well help.
Some of the print head jets will not unclog for you. If that does not work then most likely the print head needs to be replaced.
o enable the Jet Substitution mode:
To disable the Jet Substitution mode:
NOTE: If necessary, press the [Up] or [Down] arrow button to select [Save Change and Select Another Jet] to substitute more jets.
SOURCE: Lines along edge of paper
If the problem re-appears and updating the firmware (from office.xerox.com) does not help you are most likely looking at a replacement processor board.
SOURCE: Xerox Phaser 7760 Prints White Lines Diagonally Across Page
That is normally caused by a bad developer housing.
SOURCE: 7760 DN printing crooked from tray 5
7760 dn solo tiene dos trays...
entiendo q la tray 5 sera el by-pass or left tray
la ultima vez q me paso eso es pq hicieron etiquetas q dejaron residuos de cola en el bafle de los rodillos de partida del by-pass, el papel se frenaba por el lado in y torcia el papel
