Coffee Makers & Espresso Machines Logo
M
Mickey Nuttall Posted on Dec 15, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
90' Turntable #933-2849 has no track power from even numbered positions. How do I fix. Mickey
Using DCC
Inky Fingers
Level 3:
  • Master 705 Answers
  • Posted on Dec 16, 2014
Inky Fingers
Master
Level 3:
Answers
705
Questions
0
Helped
433748
Points
1443
What make and model coffee machine has a. 90' turntable? Please clarify or move your post to the appropriate section.
2answers
My Haier 50" tv won't start, there is power and when I turn it on, the red light changes to blue for few seconds and it goes back to red, nothing on the screen
Hello Mickey,
I am not familiar with your Haier...
If successful DO-IT-YOURSELF
fix is what you are interested in...
Get on the internet... use your model number to find
your power board..
Track the EXACT position of EVERY WIRE & SCREW...
Force NOTHING.
WEAR an anti-static wrist strap...
https://www.amazon.com/Rosewill-Anti-Static-Components-RTK-002-Yellow/dp/B004N8ZQKY/ref=sr_1_3?ie=UTF8&qid=1502716745&sr=8-3&keywords=anti+static+strap
and certainly verify your pack numbers yourself.
These assemblies are VERY SIMPLE... but take notes and photographs of your progress.
CARELESS will guarantee failure.
Shopjimmy.com ... AMAZON... and for the near future
SEARS sell power packs...
Sample part:
http://www.ebay.com/itm/HAIER-50E3500-POWER-BOARD-TV5001-ZC02-IP0F247785B-/172793395801?hash=item283b49fa59:g:hYsAAOSwcUBYNd1~
You can do this (maybe)
Thomas only runs on power track
PDF]EZ Command instructions.qxd - Bachmann Trains
www.bachmanntrains.com/.../EZ_Command_instru...
Bachmann IndustriesINPUT: 120 VAC 60Hz. OUTPUT: AC 16V 1000mA ... After the track connections are complete, plug the Wall Pack Power Supply into a standard 110 ... If your Control Center does not power up as shown here, disconnect it from the Wall Pack ...
[PDF]5 Amp Power Booster - Bachmann Trains
www.bachmanntrains.com/.../449105-AMPInstructi...
Bachmann IndustriesNOT RECOMMENDED FOR CHILDREN UNDER 14 YEARS OF AGE. ... The E-Z Command® 5 Amp Power Booster provides extra power to the track so ... locomotives on our N, HO, OO, S, O, On30, or Large Scale layout. ... Make sure the smaller plug end is connected to the DCC input jack marked DCC IN (figure 2) on the.
When trying to give a decoder a new address i keeps coming up error code 12how do i get around this
this might be due to electrical "noise" on track or near by , me I use a one piece dedicated track with its own power supply to power my dcc stuff when programming them , if your not in that position financially then try using a short one piece of your own track that doesn't have ends or go anyplace , also try to avoid programming near floursent lights these things throw out tons of electric noise !! and it drives my command system nuts sometimes
1helpful
Aiwa PX-E850
Hi, most likely the auto function needs resetting. With the power off turn the platter manually clockwise a dozen or so times. Power up and play. Cheers john.
1helpful
Denon CD deck
This unit needs a service visit. It may be a common problem with that model but to me it sound like a power supply issue as when you play a disc more power is used to rotate motors and move the sled. This is indicating to you that it is in a weakened condition and will soon fail more significantly. The problem may be as little as a solder joint or a defective Filter capacitor which is common in some models of equipment.
Although my turntable seems to be fine there is hardly any sound coming through my amp/speakers from it. I'm using a different power lead for it since I've lost my original but it fits fine an
your needle has worn down, or the RCA leads(red & white) arn't plugged in to the phono socket on the amp,or you haven't selected phono on the source select,or you have the tape monitor button switched on.
I have a Sony turntable - model number # PS LX295. I have been looking for a reciever for it. So far nothing, What can I do to power the turntable?
It is powered by 12v. Check any extra power adapters you have as 12v is common for a power adapter. 120ACinput to12v DC output but not more than 600ma. The one I'm using runs 400ma. BUT, the problems is that since the line level output of the LX295 is much lower than other line levels (CD player, tape player) you'll need a pre-amplifier. I added power to mine but don't have a pre amp to boost the level enough for the computer to even register it. Sony's tech sheet on the unit says the output lines runs 2.5 mV while one coming from a tape deck or cd player runs 250mV. You can buy record player preamps as many record players are the same way. Of the 3 power wires coming out of the unit, the one with long dashes on it is the negative and the one on the other side is positive. I'm not sure about the one in the middle as I've tried it both + and - and the unit runs the same without anything to it. Probably a remote signal from the original unit. It's easier to go to a Goodwill store or get one made for "stand alone" use.
2answers
Phillips microwave oven vt255/bl tuntable does not rotate
HELLO.
The turntable is the unit in the center of a microwave that you set your food on. It rotates during the microwave cycle, making sure all parts of a dish are properly heated. These are typically made of either hard glass or microwave-safe plastic.
Your microwave turntable may not turn due to one of these problems explain below
(1)If your turntable is removable (as many are for cleaning purposes), it may have come loose from this turning mechanism.place the turntable properl on the turning mechanism.
(2)If your turntable was previously working and now does not any longer, check the settings on your microwave's LCD display to make sure you haven't accidentally turned off the turntable.
Most microwaves have different settings that the user can select with the press of a button, like a "Defrost" setting or a "Popcorn" setting. Certain microwaves may stop the turntable from turning during certain pre-programmed selection modes. Stop your microwave and don't use a pre-programmed mode. Instead, just specify the time using the number pads and start your microwave to see if your turntable begins to rotate again.
(3)The rotating mechanism on the inside of your microwave that rotates the turntable is actually connected to a small motor on the inside of your microwave's case. If this motor burns out or stops working, the mechanism will stop turning. This is something that needs to be replace.
FOLLOW THESE STEPS TO REPLACE THE FAULTY MOTOR.
THINGS NEEDED.
* screwdrivers
* replacement motor
* specific microwave information and part number
1 Open the microwave door, and carefully remove the turntable tray. Also, remove the frame that the turntable is positioned on. Both the turntable and the frame are not secured in the oven, so removing them is a quick process.
2 Remove the bottom panel of the microwave. The Microwave Wizard website explains that the number of screws securing the panel varies depending on the manufacturer and specific microwave. Once the bottom panel is loosened, disconnect its wiring harness in order to completely remove the panel.
3 Locate the turntable motor. The Microwave Wizard website explains that the motor compartment should be positioned below the center of the microwave. Unscrew the motor, disconnect the wires, and remove it from the microwave.
4 Determine the specific part number for the turntable motor so that a correct replacement can be purchased or ordered. Position the new motor into the shaft in the bottom of the microwave. Screw the motor securely into place.
5 Test the microwave to make sure that the turntable motor is operating correctly. The Microwave Wizard website explains that the motor can make noises if it was not positioned evenly in the shaft. Reconnect all of the wires that were detached when removing the old motor.
6 Reinsthall the microwave's bottom panel parts, and secure all of the screws in place. Reposition the turntable frame in the bottom of the microwave and place the turntable on top of it. Test the microwave in order to make sure that everything is working correctly.
Thanks.
The train set didn't come with directions and we can't get it to work. We have put batteries in it and now we are stuck! Can you help?
There is an on off switch on the side,also you have a selection switch on the same
side. Select either round track or straight track. Place the train on selected track,the
straight track with the arrows pointing in the direction of travel,then press the
Mickey symbol on the train body. Wipe the bottom of the train now and again to
make good contact.
Hope this helps and the little one has as much fun as my grandson.
Top Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Sulejman Sulejmani
Sulejman Sulejmani
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
