Hi Crystal:
My understanding:
"Crank" means turn over under the power of the starter.
"start" means it starts running
If your vehicle will not "crank" I would think that means you may have a bad battery, terminal, or connection, or ignition switch, or solenoid, or starter.
If your vehicle will not start, I would be thinking that it is cranking but won't run, so I would be looking for a spark (ignition) problem, or a fuel delivery problem.
Hope this helps.
I really don\'t understand what you mean by skip on the LQ 2180 dot matrix printer... Could you explain further. Waiting for your responds as to helping you resolve this issue.
Hello,don't really understand the code you mean,i have to inform you that there is no calling code.you have to bear with me.or you can as well explain the type of code you talking off.
take care.
if your dvd power led is on , try to replace its data cable , if not solved that mean your windows has a bad system files and you need to re-install windows finaly i hope it solve if not that mean your dvd is damaged
if you see that is helpful please don't forget to vote me
best regards
I'm not sure if you mean the actual product code how the game is bought or the product key where you install the game with.
If you mean the exact product code (that gets read to buy the product, so NOT for installing the game) for AoM: the titans (the expansion only) it is 805529486478
I myself have a package that include both titans and the regular AoM, and for that it is 805529879355. If you do not mean the product code but the product key code (TO INSTALL THE GAME), then you should look above your CD, usually it shows "product key" and then 25 letters and numbers. Type that code in to install. If it is not above your CD in the CD box, then look on the backside of your manual. A CD product key is personal and all codes are unique, meaning if you use the code once, you can't use it again, meaning you can only use your own code, and you cannot for example google it. I hope it helped. Usually these two get confused, but I think you mean the second one to install it, because the product key isn't good for anything really, except finding the game on a database.
