Hello;
My name is Peter. I am a retired field service appliance technician.
I assume you have an electric oven.
You have a defective individual burner control.
1.) Pull your oven out so you can get behind it.
2.) Unplug your oven.
3.) Remove the upper back metal cover.
4.) At the top in the center is your main oven control board. On the left are two burner controls and on the right are two burner controls.
5.) Inspect the burner controls for burn marks or melted wires.
6.) Finding the bad control unit, pull the control nob off the front.
7.) Unscrew the burner control in the front.
8.) Remove the connectors on the burner control.
9.) With the burner control in hand. re-attach the upper metal back panel on your stove.
10.) Pug in the stove and push back in place.
11.) On the burner control that you just removed note the part number. Search on the internet for best price.
12.) Continue to use your oven without the burner control.
13.) Install the new burner control when received. Remember to un-plug.
I have a Moffat of about this vintage. Are you saying you can't find where the fuses are? Mine are underneath the left-hand drawer - the drawer under the warming oven. I just pull the drawer out and I can see them.
most stoves require a 4 wire plug..red, black, white and ground..the white is needed for the 110V to work properly..ground is there for safety incase something shorts out it will blow a fuse/trip circuit breaker
*Own a Kenmore? Department storesbrands can be a pain as it is difficult to figure out which manufacture has made your product. This link hereshould help to find out which manufacture has made yourKenmoreAppliance.
we found the flasher curcuit had no power to the hot prong. So my friend wired the flashers hot prong into the radios fuse curcuit to get power to it and put a separate 10amp fuse on the new lead.
