Sony Xperia M2 D2305 8GB Smartphone Unlocked, White Logo
David Williams Posted on Dec 14, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to hard reset xperia m2 - Sony Xperia M2 D2305 8GB Smartphone Unlocked, White
guruaid_cs
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Sony Master 906 Answers
  • Posted on Dec 18, 2014
guruaid_cs
Sony Master
Level 3:
Renaissance:
Answers
906
Questions
0
Helped
153305
Points
2073
Please visit the below link and follow the steps to hard reset Xperia M2:
http://www.hardreset.info/devices/sony/sony-xperia-m2-dual-d2302/
GuruAid.com
1 Related Answer
kronoguy
Robbie Sleepy Whitworth
  • 248 Answers
  • Posted on Nov 23, 2012
SOURCE: xperia u hard reset
http://www.sonymobile.com/gb/tools/update-service/
click on Download update service
follow on screen instructions, to erase and factory reset phone.
My sony xperia m2 screen still can't unlock, can you unlock it?
Download onto your PC, Sony Passlock Remover and follow the prompts.
Can you please undo mcafee mobile security on my xperia m2?
If your device is locked, the default.McAffee password is 123456, then go to setting L's and remove it as a device administrator, then you will be able to uninstall it.
1helpful
How can i unlock my xperia m2 screen on 0832011871?
Download and install Sony's Passlock Remover on your PC. Once installed, connect your device and follow the prompts.
1helpful
Does anybody know where to get network unlock code for xperia m2 for free
Hi if you want to unlock your sony xperia m mobile from network lock then code is the best solution to unlock it .You can purchase code from sites like Unlock-Zone.com for affordable cost .You first check that whether the code is available for your country and network provider .If yes then pay for it and unlock your phone ...
Sep 20, 2014 • Cell Phones
1helpful
2answers
Sony xperia t troubleshooting
restore settings
or this one note all data will be deleted
How to Soft Reset or Reboot or Restart SONY XPERIA T LT30p ?
To soft reset SONY XPERIA T LT30p, press the POWER BUTTON KEY for several seconds, we will see the menu to restart or turn off. Choose restart/reboot than the SONY XPERIA T LT30p will do the soft reset or restart. This is safe to do because non of important data or applications will wipe or erase.
#Option 1, Hard Reset SONY XPERIA T LT30p with Software Menu :
  1. Make sure the battery is charge properly
  2. Turn on SONY XPERIA T LT30p smartphone
  3. Don't forget to backup all important data
  4. Go to menu: Setting > Backup & reset > Factory Data Reset > Erase internal storage > Reset Phone
  5. Choose Erase everything to continue and confirm you ready to do the format SONY XPERIA T LT30p
  6. The SONY XPERIA T LT30p will continue the step until ready to use in clean factory default.
#Option 2, Hard Reset SONY XPERIA T LT30p with Flashtool applications:
  1. Flashtool in the applications from Sony can be download from Sony website.
  2. Flashtool software need to installed in you computer and ready with USB data cable
  3. Make sure SONY XPERIA T LT30p battery is charge properly or full charge
  4. Power off SONY XPERIA T LT30p
  5. Boot SONY XPERIA T LT30p to flashmode with using: Volume Down Button and connect to USB cable at No.1 above
  6. Follow the menu at you computer display, it is easy to understand the steps.
#Option 3, Hard Reset SONY XPERIA T LT30p with Hardware Key Button:
  1. Make sure the battery fully charge
  2. Do not forget to backup all important data
  3. Turn off the SONY XPERIA T LT30p
  4. Press and Hold together: Power Button + Volume Up Button for several seconds
  5. Follow the menu at LCD screen to continue the hard reset SONY XPERIA T LT30p
You can choose the step options above to do hard reset while the SONY XPERIA T LT30p get problem or not running well. But we always suggest to do routine backup before your smartphone get problem. If SONY XPERIA T LT30p already stuck or run slowly or not responsive, then better try to do backup as you can because all important applications will be wipe or removed from SONY XPERIA T LT30p after doing master reset, but some data which saved at memory card will be safe, better to remove the microsd memory card before doing the hard reset.
Jun 16, 2014 • Cell Phones
2helpful
3answers
How to nulock sony xperia s lt26i
solution 1, Hard Reset SONY XPERIA S LT26i with Software Menu :
  2. Turn on SONY XPERIA S smartphone
  4. Go to menu: Setting > Backup & Reset > Factory Data Reset > Reset Phone
  5. Choose Erase everything to continue and confirm you ready to do the format SONY XPERIA S
  6. The SONY XPERIA S will continue the step until ready to use in clean factory default.
solution 2, Hard Reset SONY XPERIA S LT26i with Flashtool applications:
  3. Make sure SONY XPERIA S battery is charge properly or full charge
  4. Power off SONY XPERIA S
  5. Boot SONY XPERIA S to flashmode with using: Volume Down Button and connect to USB cable at No.1 above
solution 3, Hard Reset SONY XPERIA S LT26i with Hardware Key Button:
  3. Turn off the SONY XPERIA S
  5. Follow the menu at LCD screen to continue the hard reset SONY XPERIA S
Be careful before doing this step to master reset, because all important data and applications will be removed from SONY XPERIA S, we always suggest you backup all important data before performing the hard reset.
Top Sony Cell Phones Experts
Aron
ADMIN Eric
ADMIN Eric
NOEL
NOEL
Are you a Sony Cell Phone Expert? Answer questions, earn points and help others
