Most likely a Singer presser foot will not attach to your Bernina. They are not interchangeable.
You can also probably use something like this: https://www.youtube.com/watch?v=JOImaKwv4fU but you need to purchase a snap-on shank adapter for your Bernina, like this: http://www.ebay.com/itm/PRESSER-FOOT-SNAP-ON-SHANK-ADAPTER-BERNINA-OLD-STYLE-530-1630-0062617000/282290526069?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D2%26asc%3D40807%26meid%3D4fe9a7b6fca84bb3adef4f466cc8776f%26pid%3D100005%26rk%3D2%26rkt%3D6%26sd%3D401187382421
Or, are you talking about the presser foot? Bernina #033? You can usually find a replacement through eBay, or even purchase a snap-on shank and pick up a snap-on buttonhole foot. But, if you have another zig-zag foot or open-toe presser foot, you can probably get by with using it as long as you can see your marks on the fabric when you stitch.
If you are actually referring to a buttonhole attachment like what is available for new machines, you may be out of luck. Probably not any available for this older model. The automatic buttonhole attachment usually has a sensor that your machine does not accommodate and the buttonhole attachments have a different shank that will not work on the older machines.
However, the buttonhole dial on your machine should work just fine. You just need to do more pre-work, ie measuring the button and marking the buttonholes on the fabric before stitching them. Even if the machine is only a zig-zag, buttonholes can still be done on them. Just be sure to practice a few buttonholes on scrap fabric before trying them on your garment. Get the stitch length so the zig-zag stitch has no gaps between threads but also does not overlap the thread next to it. Also, check that the tension does not cause the fabric to pucker (be sure to use a stabilizer between the fabric to prevent the fabric from stretching or distorting).
I can't be specific, but I had problems with my Bernina Virtuosa 160 automatic buttonholer.
Check the feeddog teeth height. At their highest point, the FRONT teeth height should be 0.05mm higher than the back teeth.
Good luck.
Esther. England.uk
Difficult to say whether your current foot can be repaired or even if a new foot is the answer. I believe the auto buttonhole needs to be calibrated to the machine, but not sure that is the issue with your machine.
You can sew a buttonhole without using a buttonhole foot--not really difficult as that's how it was done for many years before the manufacturers developed the specialty foot. (My machine came with a buttonhole foot but I still make mine the old-fashioned way because I determine how they will look rather than the machine making that choice for me.)
Practice a few times on scrap fabric and write down the stitch widths & lengths that work the best for you so you can replicate each stitch to look alike.
Sew Buttonhole without Buttonhole Foot by Create Kids Couture (also don't care for this type--don't like the look when the fabric is rotated and stitched across the end of the buttonhole--the bartacks on the other buttonholes is much more professional)
Hi, you must have an 1130S which means it could also be a circuitboard issue. If the LED/LCD light for the buttonholer does not flash you either need a new RET-Print (circuitboard) or a new buttonhole foot. Sorry to say that you DO more than likely need a new buttonhole foot according to my manual on this machine. No way to repair the foot that I know of.
You should bring the machine in and try it first.
Guess not all news is good news. Sorry.
Rick (Bernina tech)
