Knocking when start of spin cycle - have to keep on redistributing the load or taking items out
SOURCE: washing machine keeps stoppping.
Hi just read your posting.Now when the machine starts to beep it will show a series of lights.These lights will be in a row of 8 lights.Starting from the left to right which ones are lit when the machine is beeping?Is it the 2nd and 5th or the 4th and 7th ---etc---?Please reply with additional information and I can help you further.
SOURCE: Fisher and Paykel Washing Machine
Hi just found your posting.Do you still require help?The problem with your machine sounds like your suspension rods are faulty.Please reply and I can help you rectify this fault.Looking forward to your reply.
SOURCE: Every wash, the machine on rinse/spin cycle, makes
Hi Sandra, I'll have a look into this. This machine isn't my usual brand, so I'll have to see what I can find out for you. I'll get back to you by tomorrow :) Joe
in side your washer you have counter weights they look like breeze blocks are these tight also there should be a couple of what look like small shock absorbers have a look to see if thet are still working the only other thing i could sugest is make the loads smaller especialy with jeans and wooly jumpers as these soak up a load of water hope this helps ivan
Google this Neptune TL Washer FAV6800AWW 5 post down.
Here ya go.....in this post I discuss the issue related to unbalance error codes DC and UC;
Your FAV6800A or FAV9800A is going off balance with DC or UC unbalance error codes during spin cycle and you see/hear the wash tub banging around at the start of Spin Cycle of the wash cycle or a Spin Only cycle. If this is the condition the TDS (Tub Displacement Sensor) is working as designed and signaling the Control Board properly of an unbalance wash load condition.
The Control Board receives a varying D.C . Voltage from the TDS sensor and if the out of range D.C. Voltage limit continues the Control Board will halt the Spin Cycle and try to redistribute the wash load. If you are interested I will show you how to monitor the TDS input to the Control Board with a DVM.
The Control Board then starts the Spin Cycle again. If the wash tub/basket out of balance condition continues the Control Board will attempt another redistribute of the wash load. After several attempts (4 to 5 I believe) the Control Board will shut down the Spin Cycle and send a error code DC or UC to the LED display of the FAV6800A, my machine type. And I believe a text statement to the LCD screen of the FAV9800A machine i.e. something like "Unbalance Condition" I'm not sure what the text message is.
If you need help open a post in that repair forum and I will try help you through your issue.
The forum is free and my time is free I just don
