1998 Honda Accord Logo
Sukmoon C. Posted on Dec 12, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to fix my flat tire?how to fix my flat tire?how to fix my flat tire?how to fix my flat tire?how to fix my flat tire?how to fix my flat tire?how to fix my flat tire?how to fix my flat tire?how to fix my flat tire?how to fix my flat tire?
T. Anthony S.
Level 1:
New Friend:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Contributor 17 Answers
  • Posted on Nov 22, 2017
T. Anthony S.
Contributor
Level 1:
New Friend:
Night Owl:
Answers
17
Questions
0
Helped
24301
Points
17
This video shows how ver easily. Couple of cheap parts from Amazon or any auto parts store.
https://m.youtube.com/watch?v=KZxkvvGsz08
John White
Level 2:
Habit-Forming:
Filmmaker:
Uploaded 5 video answers.
  • Expert 117 Answers
  • Posted on Aug 19, 2016
John White
Expert
Level 2:
Habit-Forming:
Filmmaker:
Answers
117
Questions
Helped
78424
Points
443
JOHN ADLINGTON
Level 1:
New Friend:
  • Contributor 10 Answers
  • Posted on Dec 12, 2014
JOHN ADLINGTON
Contributor
Level 1:
New Friend:
Answers
10
Questions
0
Helped
4637
Points
25
3answers
Can i use the fix-a-flat with more than one car
what ever is a 'fixd" to start with
How to fix my flat tyre on my toyato 2013 model, the back wheel on the left passenger side a short nail from the board that grips carpet in place either was put there or i might have run over it,
How to fix my flat Alzer, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to fix flat car tire
How to fix flat tire with tire plug kit tire repair kit in this video
How to Fix Flat Tire
Will fix a flat mess up the tire sensor
please just go buy a Safety Seal Kit and plug it.
That Fix a flat stuff will cost you a bundle when you need new tires.
Can you put fix a flat in a nitrogen tire?
Yes, you can put fix a flat in a nitrogen tire. Just remember that fix a flat is often a temporary fix and you should get the tire properly patched or replaced. I have heard of people driving forever with fix a flat and some where they just make it to a mechanic's. Good luck! http://www.xlautony.com/products
1helpful
My car shakes when i get to 55mph or higher and shakes when i brake to stop
you have a warped rotor and possibly an imbalanced tire as well..did you ever use "fix a flat"? that will do the same thing as well to fix that? you'll need to bring the tire in to a tire store and empty the remaining fix a flat stuff and the tire leak fixed correctly. if fix a flat was never used it's the first two things I mentioned imbalance in the rim/tire or warped brake rotor
3answers
How many cans of fix a flat can i put in one single tire?
it depends on if you want to be able to fix the tire. the compound in fix-a-flat will keep the patch from sealing inside the tire.
so instead of a $15 repair, it might be a $120 tire.
1helpful
Changing rear flat tire
Find jack follow instructions to raise vehicle after parking brake is on. Remove lug nuts and take wheel with flat tire off. Replace with the spare tire and tighten lug nuts. lower vehicle, put jack , lug wrench and flat tire in vehicle. Drive to a tire repair store and fix the problem.
Run/Tire Issue
Run flats cant be repaired. You can however just replace all the tires with a different style tire like most all vehicles on the road and carry some fix-a-flat or a compressor and plugs for emergency needs till you can get this punctured tire patched.
2answers
How to change the flat tire? Can not remove tire off the rim. How i get the nuts off?
While there is road side assistance that can help in times of need. It's imperative that every driver should know about how to replace a flat tyre. After ascertaining that the tyre is flat, you should check the link which will guide you to change the flat tyre with the spare one, have a look
=> DIY 10 easy steps to change flat tyre
=> How to Change Flat Tire
Top Honda Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Honda Expert? Answer questions, earn points and help others
