There isn't much I can add to Gordon's Appliance solution.
thats exactly where I'd go for the solution .
Check the drain pump, located under the machine. It might have something stuck in it. coins, toothpicks etc can cause this. Unplug the wiring connector, remove the three screws and two hoses. Usually junk gets caught in the inlet
SOURCE: Won't Run
The humming usually means the motor is trying to start but can't either because of weak windings or not enough electrical power. Need to check the motor control.
SOURCE: Maytag washer wont start after it fills
Did you replace the pressure switch its a round plastic thing with a plastic tube at the bottom and six electrical connections
SOURCE: I have a Maytag Bravos MTW6600 top load washer. I
Hi When you hear a humming sound from the motor it means that
the motor control is bad and should be replaced. If you still want to test the motor control then you can take it apart and test the motor before replacement. Hope this
helps...please post back for further assistance. Daniel
SOURCE: Maytag bravos washer is making a loud tapping
Their could be something between baskets in the pump. Remove the inner basket and inspect pump.
Bravos service manual and more HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: My Maytag Bravos washer stopped on the spin cycle
You might have items between tubs. Are you using HE soap in the correct amount?
Service manual
