Blue and red dots appear about two inches apart in a row across the colored picture.
THIS machine has tendence to SPILL toner. Remove toner WASTE RECEPTACLE and GENTLY remove toners and DRUMS. check residuous acumulated over the transfer belt (do not touch or use chemicals on FUSER OR TRANSFER BELT .ALSO CHECK IF THERE IS TONER RESIDUOUS IN THE TRAY OR PAPER PATH. IF USING AIR CAN; COVER THE LASER UNIT (OF EACH COLOR) TO AVOID ACUMULATE IT AT THE LASER COMPARTMENT.
SOURCE: Washed-out color.
Looks like you need some printer profiling...
Washed out prints can be caused by several things... Let's see if we can sort it out.
It could be your printer, or it could be your monitor giving you false readings.
Printer Profiles: If you do not have the correct printer profile, then your prints may turn out faded. This is a gamma thing. You are encouraged to calibrate your monitor, and go to the printer manufacturer web site and look up your printer to see if they offer the correct RGB and CYMK printer profile.
Poor quality paper: most likely the problem is a poor quality paper. You did not indicate what printer and what paper you are using, so we cannot help much. However, try a sheet of the high quality photo paper and see if the colors print more vivid and saturated.
If the above doesn't help, I suggest you find someone else with a different printer who is willing to bring it over and print from your computer. That will proof the printer either in or out of the equation.
If none of this helps let us know and we'll walk you through the creation of a custom printer profile and custom color space.
SOURCE: Lexmark X83 printer has streaks printing color pictures (but text is fine)
This is the problem with the cartridge if you brought original Lexmark cartridge you can get it exchanged as the cartridge is nay be defective and the cartridge comes with one year warranty...........................................
SOURCE: my priter prints blue lines across all colored pictures or text
Have you tried cleaning the print heads or replacing the color cartridge? where as it it printing black fine it leads me to believe the problem lies in the color cartridge. my first recomendation would be to run the clean print head wizard in the printer settings and if that does not work then replace your color cartridge.
SOURCE: new printer cartridge in Lexmark 8350; blue lines on pics and papers
In Lexmark printers the ink cartridges can get clogged sometimes. Re-cleaning the nozzles might help fix your problem. Make sure your ink cartridge is not getting empty.
Hope this helps.
