Maytag fills with water then shuts off during rinse cycle. I emptied water with a bucket, and it would turn back on and refill. I moved the timer to the spin cycle and emptied the water. Now, it won't turn on.
The machine control board is programmed to allow a maximum continous fill time of six minutes
or an accumulated fill time of 8 minutes for each full wash cycle.
If the required fill time exceeds the time limit, the washer will shut down.
This is to prevent flooding in the event there is a loose hose clamp or damaged air dome hose.
Check the incoming water lines for a minimum pressure of 20 psi.
If lower, the customer can use smaller clothes loads and reduce the pressure to 10 psi.
An alternative solution would be to change the plastic inlet screens to metal screened washers
and remove the nozzle extender found in the water valve inlet hose near the dispener inlet."
