SOURCE: Dishwasher Repair
It could be a motor or a pump issue. The dishwasher has a motor that attached to a pump which forces the water up into the sprayer arms and during the drain cycle, it pushes the water out of the dishwasher. The motor (and pump) located beneath the dishwasher. Check if motor spins. In case it spins, the problem is with the pump ,in case it doesn't spin it could be a motor problem or a motor and pump problem. Good luck
SOURCE: AEG Favorit 40850
yes its the flood sytem control underneath you might have a leek like i did it was the heater leaking
replaced it and now its running ok its a eay job to replace
SOURCE: FDW60 Fast and Delicate Lights Flash
This is a bad control board that if replaced will only repeat in a short time .My advice is to contact the manufacturer and complain,you have the right as a consumer to do so.
SOURCE: My Siemens Hydrosensor dishwasher seems
It is obvious the drain or pump out is not working. There is a blockage in the outlet. Check the drain under the sink nby removing the hose and making sure the hole is not blocked. The pump in the dishwasher may be blocked. fixing this may not be within your field of expertise and a technician may be needed. Good luck
Testimonial: "After taking as much apart as I felt capable of to make sure there wasn't any blockage...it confirms my belief that it must not be pumping the water. "
The scum, film and white
residue problems have started since the reduction of
phosphates in dishwasher detergents.
Here is a tip that
will help you to solve the problem of films, residue, and scum in
your dishwasher.
Dishwasher
Residue and Film on Dishes
heatman101
