Need instruction on how to set up
Q1. How to set on / off times?
A1. Shift the red actuator pin to the desired on time
shift the black actuator pin to the desired off time.
Q2. What is the shortest time interval?
A2. 15 minutes.
Q3. Maximum switching times?
A3. One "on" and one "off" setting.
Q4. Can you override?
A4. Yes, use the override switch.
Note: If the main power is turned off the timer will need to be reset.
To set the timer to the current time you will need to turn the dial in a clockwise direction until the smaller arrow (Line) on the front face is pointing to the current time.
Regards,
Arlec Customer Service
+61 3 9982 5111
