Nikon D3000 Digital Camera Logo
m
miguel leiva Posted on Dec 10, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why my Nikon d3000 doesnt work with completely charged battery?
Change battery and put the camera on and off , change objetives
Ozzie Morrow Jr.
Level 2:
Champion:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Nikon Expert 305 Answers
  • Posted on Dec 10, 2014
Ozzie Morrow Jr.
Nikon Expert
Level 2:
Champion:
Cheetah:
Answers
305
Questions
Helped
65863
Points
398
I dont know what you did or didnt do send it to nikon they will tell younwhat the problem is how much it cost to fix and how long it takes to fix then they send it back to you if its under their warranty they fix it free.
Art Scott
Level 2:
Novelist:
  • Nikon Expert 357 Answers
Art Scott
Nikon Expert
Level 2:
Novelist:
Answers
357
Questions
0
Helped
68884
Points
473
First off, have you dropped or otherwise impacted the camera, taken it to a sandy area, or spilled a sticky drink or water on it?
If dropped, then there is a flex under the bottom on the rewind side (or where it used to be) that can be broken by impact. Nikon does not sell this part, it would have to go to Nikon.
Check the mirror. Sometimes it is pushed to the left by impact and lodges against rather than on the stop. You should be able to gently lift the mirror. If the mirror is stuck, you may be able to gently lift it up and free it until it once again rests on the top of the stop.
There were a lot of defective main boards for this model. If you have consistently had problems, then send it to Nikon. I believe there have been 3 modifications of this board to solve a non-power problem.
How old are your batteries? If your batteries are more than a year old, especially if they are non-Nikon batteries, they may have gone bad and not be able to store enough amperage to operate the camera.
Testimonial: "Because i didnt know what is the problem i buy a new battery and charged it so its not the battery Not problem with the mirror neither. Its not stuck"
Nikon lithium ion battery not charging
Make sure you ha e the charger plugged in the wall, thats a common mistake then put battery in port make sure it clicks in tight the light will start to blink the its charging. When it stops blinking it is charged
1helpful
Nikon d3000 sat in rain....put in bag of rice to dry it...now message on screen reads"this battery cannot be used. Please use battery designated for this camers."
Could be the error has nothing to do with the rain at all. The camera is perhaps 4 years of age? some batteries last for 10 years. But some can't survive 2 or 3 years. All depends on how they were used or abused. When normal charged and discharged in a regular cycle, the battery can survive 1000 cycles. When left alone for very long periods it damages the battery. See if you know someone with a Nikon camera that uses the same battery and try his battery in your cam and put your battery (if he or she allows this) in the the other camera. If another battery works correct, no need to test your battery in another camera.
You also could look in the battery compartment is the connection points are corroded by the water. ls check the contacts on the battery. Eventually clean it with contact fluid. don't scratch the contacts, because the will corrode very quick after that.
1helpful
Nikon D3000 battery won't charge when plugged into my pc
It's not supposed to. In fact, connecting your camera to your computer will drain the battery faster since the camera has to use juice to communicate with the computer (even if only to say it has nothing to say). You need to take the battery out of the camera and put it into the supplied charger in order to charge it.
1helpful
Can you charge the battery of a Nikon D3000 in the camera
No. The D3000 does not contain any charging circuitry.
Can someone help me on my nikon D3100 freeze problem?
New battery that is fully charged. My Nikon D3100 has had the problem of freezing every ten or so pics since it was a couple of months old. Still does it today after six months of use. I take a few hundred pics with it when shooting but only shoot once or maybe twice a month.
Have to take the battery out, put it back in etc. each time. Sometimes it allows me to power off and then back on but either way it's a pain in the rear and a serious "time waster".
1helpful
Coolpix S3000 will not charge
The camera does not charge the battery. You need to take the battery out of the camera and put it into the battery charger, then connect the battery charger to an electrical outlet.
Nikon D3000. Exposure lock with focus problem.
Probably your lens causes this I think. Please check these.
1. Your lens may cause this. Change it and try again.If you do not have another lens then go on to check the next instrutions.
2. Check your lens AF button. It should be switched to AF.
3. Turn off and on the camera and try again.
4. Check your battery charging.
5. Your lens should be cleaned complitely. Please check its clearity.
I think it will work. But if it does not work properly again then your camera should be checked.
Clean your camera mirror. For this:
1. Turn off your camera.
2. Remove your lens.
3. Clean your mirror without using water or any other liquid or any other chemicals. Use only special cleaning liquid that is made for lens cleaning.
4. If it does not work then your camera body should be checked electronically and mechanically. This check can only be done with an authorized service tecnician. So you should send your camera to your service dealer.
1helpful
Nikon d3000 autofocus issue
you should change the focus lock to AF-S, instead of AF-C
2answers
Nikon D3000 Monitor is black when taking a picture - any way to change it?
You can get the shooting information on it. If you're looking to use the D3000 as a point&shoot by viewing the image on the screen, then no, you have to use the viewfinder.
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
